PDA
View Full Version : 2005 GTO dyno graph
HybridSS
08-11-2004, 01:00 AM
This was on LS1tech. As some of you know the new LS2 will be in a ton of new cars and trucks next year along with aluminum 5.3 versions in several other cars. The new LS2 is rated at 400 hp. Here is a dyno graph of the LS2 in a 05 GTO.
The GTO seems to have a power robbing drivetrain since the 04 ones are only dynoing in the 270 range to the wheels. So this dyno looks exceptionally good. I think 12s stock may be possible.
http://www.ls1tech.com/GTO/dynoLS2gtoStock.gif
Mars_302
08-11-2004, 01:06 AM
350 to the wheels stock? Thats almost up there with Z06s. Thats crazy
HybridSS
08-11-2004, 01:12 AM
I think its basically an identical engine. But of course GM will probably rate the GTO at 395 instead of 400 for the C6.
Tom N
08-11-2004, 02:12 AM
Do you know if the dyno was with a manual or automatic GTO?
corey r.
08-11-2004, 11:31 AM
Glad the GTO is finally getting some balls!
Scott
08-11-2004, 04:15 PM
My guess would be manual since a lot of factory autos are hard to dyno because of their converters.
Sneakin Deacon
08-12-2004, 02:15 AM
all the GTO's ive seen dyno put down like 290ish in stock form.
and the LS2 is only going to be 5.3 and 6.0's?
only thing i dont like about the graph is the abrupt loss of torque at the last 1000 rpm.
Country Boy
08-12-2004, 09:38 AM
The LS2 is an all aluminum 6.0 motor. Which is going to be a VERY sought after block. Aluminum 4" bore :D
97blkz
08-15-2004, 09:33 PM
Kenny most of them I witnessed did 270-280 range!
