View Full Version : Rockford fosgate
smoke3
08-03-2004, 07:45 PM
ok i have a 800.2 amp its not the brand new ones it the one before that the punch series.
im trying to do a clean install but i have a problem
i have 4 guage wire and i can get the wire into the tiny ass whole that the amp has for a power or ground. speaker wire fits there nicely lol what can i use to convert the 4 guage to fit in there with out using one strand to go into the amp.
i had this same problem with 8 guage wiring
second proble do anyone know where i can get cap holders from
thanks
TBSpyder
08-03-2004, 08:28 PM
Cut the wire down to size. Heat shrink around it a little so it's clean.
smoke3
08-03-2004, 10:19 PM
if i got a 4 guage done to the size of a 6 guage whats the sense of having 4 guage wiring
Bumpin Expo
08-03-2004, 10:39 PM
whats the sence of having 4 guage wire if u cant use it?
smoke3
08-03-2004, 10:45 PM
yeah my point exactly
why would you wire with 4 guage if your amp doesnt accpet 4 guage?
at ANY rate, you can get a distribution block that has like 4-6 or 4-8 or whatever
http://www.tsunamionline.com/i/products/full/FDB802MAX.jpg
4 guage in 8 out....
OR
http://www.tsunamionline.com/i/products/full/RA848.jpg
4=8 reducer
PurpleEK
08-03-2004, 11:08 PM
if it an older seires it shoud have dual 8 awg in 2 for power and 2 for ground use a dist box and run two 8awg to it and its the same as 4awg
GsEclipse02
08-03-2004, 11:50 PM
thanks
i have fosgate amps also ...... you just have to twist the wire really tight.... i dont get why there bigger amps use two 8 gauges wires why not just 4 gauge ?
TIM TIM TIM
08-03-2004, 11:56 PM
because fosgate is the ghey and there stuff sucks :D
TBSpyder
08-04-2004, 12:24 AM
I'll stick with my original suggestion, it's cheap and easy....won't make a difference. I do it often. There's also a little trick that you can do, heat shrink the tip of the wire completley, screw a small screw into the end of it, leaving about 1/4-1/2" exposed, grind or cut the head off and you just made a reducer.
Bumpin Expo
08-04-2004, 12:59 AM
Yeah why does rockford make 2 8 guage in???
And tim Rockfords old shit was good. The new shit is the ghey
TIM TIM TIM
08-04-2004, 01:08 AM
yes but stereo stuff only works good for so long.. then it just gets out dated and worn out
smoke3
08-04-2004, 01:20 AM
thans tbspyder
SSpiro
08-04-2004, 10:34 AM
OR
4=8 reducer
Word. Use the distribution block. That's what I had to do, works good.
PurpleEK
08-04-2004, 07:02 PM
one is for power wire and the other is suppose to goto a cap/b2nd battery
smoke3
08-04-2004, 07:56 PM
ok i have my cap wired
battery cap amp
should it be battery amp cap
rockford said one thing and the my cap company said another
TBSpyder
08-04-2004, 08:01 PM
I'd do it however RF recommends. The effectiveness of a cap is questionable anyways....so I doubt how you wire it will make much of a difference.
GsEclipse02
08-04-2004, 08:37 PM
so your saying 1 of the 2 8 gauge is for a cap. if so witch 1 ? thanks
Bumpin Expo
08-04-2004, 08:40 PM
im sure it dont matter lol
TIM TIM TIM
08-04-2004, 08:54 PM
im pretty sure the cap is supposed to be hooked up before the amp.... what good would having the cap after the amp?
smoke3
08-04-2004, 08:57 PM
thanks alot TBSpyder i did that thing with the screw it worked perfect
as for the cap im leaving mine how it is.
thank god someone noticed... put a cap on the speaker wires? or the ground?
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
