View Full Version : help!!
crazyeclipse66
07-25-2004, 11:48 PM
Here are the specs on my sub's I have 2 of them.
Recommended RMS Power: 200W
Peak Power Handling: 400W
What size amp should i buy to get the most out of the subs. Should i get a 400watt amp or an 800watt amp? Please help me Thank you!!
kpr10is
07-26-2004, 12:57 AM
Well you dont need two threads...but get an amp that is 200 watts RMS, which might be around 400 peak depending on the amp. Look at RMS though, its more important (see other thread).
kpr10is
07-26-2004, 01:00 AM
well according to your other thread, you have two of the subs, so get a 400 watt RMS amp if its a 2 channel, or around a 600 watt RMS amp if its a mono amp.
i really dont feel like explaining parallel or series wiring, or ohm loads, but theres much more to buying an amp than watts. do a google search, or i might come back and type later if im bored
TIM TIM TIM
07-26-2004, 01:32 AM
wow..get a 2 ohm stable amp... if the subs are DVC (dual voice coil) get 2 channel or mono... if you have SVC (single voice coil) then get a mono amp
TBSpyder
07-26-2004, 10:05 AM
Stick with a mono class D either way. The JBL 600.1 I recommended in the other thread would work well with your subs as long as you keep the gains all the way down. And if you're really tight on cash, the JBL 300.1 wouldn't be a bad choice (plus you wouldn't have to worry as much about turning the gains up and cranking the volume).
crazyeclipse66
07-26-2004, 10:55 AM
Thank you i have one more question, my subs are 4OHM. What does that mean, and when lookin at amps when is says the watts at 4ohm's is that the watts they will be pushing my subs at?
crazyeclipse66
07-26-2004, 11:22 AM
250W x1 @ 4ohms
500W x1 @ 2ohms
750W x1 @ 1ohms
RMS 250-50WATTS
If my subs are 4ohms how many watts are gonna push it?
GsEclipse02
07-26-2004, 12:55 PM
Originally posted by crazyeclipse66
250W x1 @ 4ohms
500W x1 @ 2ohms
750W x1 @ 1ohms
RMS 250-50WATTS
wtf is that for an amp or a sub ?
crazyeclipse66
07-26-2004, 12:58 PM
thats for an amp, my sub's are 4ohm i was wondering how many watts from that amp would push my sub's
GsEclipse02
07-26-2004, 02:44 PM
are your subs DVC or SVC if there DVC i would just run them at 1 ohm turn the gains down a lil bit to be safe but what brand of subs /amp do u have
TIM TIM TIM
07-26-2004, 05:01 PM
most amps cant run 1 ohm...just hook them up at 2 ohms, unless you get one of the few amps that can run 1 ohm
GsEclipse02
07-26-2004, 09:09 PM
250W x1 @ 4ohms
500W x1 @ 2ohms
750W x1 @ 1ohms
RMS 250-50WATTS
if she posted it can run at 1 ohm then it can run at 1 ohm .....
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
