View Full Version : 15" sub enclosure questions
Domestic Disturbance
07-19-2004, 11:02 PM
ok, i just got an avalon 15" sub from another guy here on the forum, he had two in a fiberglass box with about 3 cuft between the two...i was wondering if 1 cube or maybe 1 14/ cubes are enough for the sub or will i tear itselff apart?
TIM TIM TIM
07-19-2004, 11:08 PM
for a 15 i think thats kinda sufficating it, but im sure the system gurus will chime in soon
kpr10is
07-19-2004, 11:17 PM
Having never seen the sub or its specs, i have no idea, but im gonna guess that your not gonna be too happy with the sound with that small of a box. Very few subs are good in small enclosures...ed for example. But the box makes the sub, so don't skimp on either.
07-19-2004, 11:22 PM
well the reason i want to go small on it is because i am going to need some trunk space, but i guess if i have to go big i have to go big
TIM TIM TIM
07-19-2004, 11:25 PM
have fun fitting a 15 in a mustang
07-19-2004, 11:38 PM
hehehe, i know right
TIM TIM TIM
12's are tight lol
07-19-2004, 11:41 PM
hell man, i had to help a friend take a box out of his trunk, took us 30 minutes just to get the box out
TIM TIM TIM
07-19-2004, 11:55 PM
:lol: fold down the back seets if it will fit.. i made 3 seperate semi-small boxes for mine and they can still get annoying to get out (altho my floor is raised 4 inches)
07-20-2004, 12:56 AM
yeah, i made a false floor for mine, its only a 3/4inch raise and it still makes it a pain
TBSpyder
07-20-2004, 01:24 PM
You've never seen the trunk of a Eclipse Spyder have you.;)
You need to find out the factory specs for that particular sub and build a box as closely to that as possible. I can almost assure you the requirements will call for a box in excess of 2 cubic ft though.
TIM TIM TIM
07-20-2004, 01:30 PM
nope, dont know anybody with a spyder...are is just a bitch because the opening is so small but im s ure you have the same problem.
TBSpyder
07-20-2004, 01:36 PM
Yeah, my opening is about 14". There's probably less than 4 cubic ft. of trunk area.
Originally posted by SupraKid
I <3 having a hatch
HATCH? BAH
I have a nice tailgate to slide it on and then have some rediculous space to work with
07-20-2004, 09:54 PM
you both suck,
anyway, i think ive got it down, im gonna put it in about a 1 1/2cuft box thats built to the floor with the amps mounted underneath the false floor with plexi to show the insides off
you should build a spare tire well box, thats prolly a cube if not alittle less.. then raise the floor the rest.. then amps on a panel between the false floor and rear deck
07-20-2004, 11:26 PM
im already using the spare tire well for the spare and to hide the amps and wires, (amps mounted upside down to the false floor wth plexi windows)
TBSpyder
07-21-2004, 07:34 PM
Box is going to be too small...half-ass the install and you better expect half-assed performance. Goodluck.
TIM TIM TIM
07-21-2004, 07:46 PM
we arent all perfect.. sorry spilner..
BTW make sure u use mdf or youll get flammed forever :lol:
TBSpyder
07-21-2004, 09:43 PM
Building a box to specs has nothing to do with perfection. It's called common sense. And don't worry, for some odd reason I think you're the only genious on this forum that would use something other than MDF. :dunno::tard:
TIM TIM TIM
07-22-2004, 11:07 AM
no, building a box BELOW specs is because you dont have the space...and i know others with plywood boxes :D
you can bulid a box out of balsa wood if you brace it enough...but itd be one solid brace lol
TBSpyder
07-23-2004, 08:22 PM
First, you should get a general idea of the space you have to work with and pick a sub accordingly. It's called being "efficient." Duh. Second, if you can only come up with 1.5 cubic ft. in the trunk of a Mustang....you're obvioulsy not trying hard enough.
07-26-2004, 11:05 PM
my math was off, the box came out to be something like 2 1/2-3 cubes
TIM TIM TIM
07-27-2004, 12:21 AM
lol cool...but that us ugly haha
TBSpyder
07-27-2004, 12:30 AM
Carpet that sucker and mount an amp rack right on the front there and you'll be set to go.
TIM TIM TIM
07-27-2004, 12:26 PM
so if you screw an amp to the side of your box that is considerd an amp rack?? thast kinda retarted cuz i have "made an amp rack" on every system i have done cuz its the easiest thing to do with them lol..
TBSpyder
07-27-2004, 02:47 PM
Where did I say that? I was thinking more of a flush mounted trim panel or atleast an extended platform hiding the wires. But while we're on the subject, technically, I would consider anything a amp is mounted to as an "amp rack"...complexity is another issue.
TIM TIM TIM
07-27-2004, 03:10 PM
i was just wondering cuz i see people saying they made an amp rack, but simply screwed the amp on the back of the box :lol:
Content Relevant URLs by
vBSEO 3.2.0 RC5
