PDA
View Full Version : buying a 240 any advice?
spoonfed
07-13-2004, 11:16 PM
I finally have my finances in a position where I can afford to buy a decent 240...any advice? I have about 2700 to spend are there any advantages to buying the later models such as the 90-93's? The one I am looking at is a 93...
spoonfed
07-14-2004, 12:12 AM
hmmm
Ichi-go
07-14-2004, 12:53 AM
I have some advice. Buy a nice one for 2 grand. Then send me the 700 so i can afford to get one.
(stupid being 16 oh well what can you do)
REY
07-14-2004, 12:51 PM
dead on !
Funk
07-14-2004, 01:32 PM
2,700 will get u a decent one these days.
it might have new tires and a working a/c
but expect to need a starter sometime soon...
i have a 93... the cams in 91's are better.. but ive never seen a difference.. like on the street wise.
J-Dizzle
07-15-2004, 05:55 PM
yea, i bought mine for 2700 , cold as fuck a/c, new tires, timing belt, battery, mmotr and tranny...water pump and such, but the exaust and hole rear of the car was shit.....now im almost selling for what i bought it for other than what ive put in(about 2k) cause the rear main seals r leaking
jason
mikeyees13
07-15-2004, 07:30 PM
It's a timing chain, not belt.
The 91+ are DOHC, that's good. The whole 91' cam thing is kinda insignificant I believe.
The one I got for 3500 had 95K, Perfect interior, good exterior, base model, good tires, cold A/C, good clutch, no problems.
Good Luck to you, and don't forget to save some of that to put some nice parts on your S13.
REY
07-15-2004, 08:27 PM
save your money and buy that white hachi w/ th 20v that was for sale....if it still is !
Epstein
07-15-2004, 08:30 PM
I got my 93 SE coupe for $1300 with a seized motor, auto tragic, and 107k on the clock. The paint was awesome and the body was very clean. Interior was better than average and had a working HUD. I traded a blown redtop longblock for a 96 motor and tranny with new clutch, and I was in business. The down sides were the horrible tires, dead compressor, and 2 slightly bent rims.
The ones to look for are 91+ for their better motors. The sub $2k ones are out there, you just have to wait. I looked every day for 2 monthes for mine. If you can turn wrenches, you can get better deals. Check the frame for dents and scars. Check the body work for repairs. Check rust in the battery tray, under the brake booster, by the door hinges, and under the mirrors. Look under the motor for leaks. Most everything can be fixed for cheap. Of course common sense tells you to test drive it. It'll probably be very squishy, but make sure it doesn't shake too much and steers well.
That's about it.
