PDA
View Full Version : system set up ?'s
GsEclipse02
07-02-2004, 04:26 PM
im thinking of re-doing my box.... i wanna do some thing that looks like tbspyders i think if i remember correctly u had ur box were when u open the trunk it just sits flesh with the top of the trunk and i think kriks is like that also ..... my ? is how u do it do u just make the box and prop it up so it sits even with the the false floor or some thing HELP me out please thanks
TIM TIM TIM
07-02-2004, 05:08 PM
when u get back ill help u.. my dad can give some ideas on how to build it, hes pretty good at that..plus hell prolly let me use the tools when needed... AND WELL BE SURE TO USE MDF BORED!!!! lol
eli
07-02-2004, 08:06 PM
u must be bored. cause its board * good luck there setups are cool
TBSpyder
07-02-2004, 10:15 PM
It's actually alot easier than it looks. Make your box without a top. Make a template of the top area you want to flush. Cut that piece and use it as the top of your box. Not sure if that makes sense to you, but I've done this type of install on a hard top dsm so it'd probably be easier to explain in person. Let me know if you need some help or just want the entire thing done for you.
TIM TIM TIM
07-02-2004, 11:05 PM
Originally posted by TBSpyder
It's actually alot easier than it looks. Make your box without a top. Make a template of the top area you want to flush. Cut that piece and use it as the top of your box. Not sure if that makes sense to you, but I've done this type of install on a hard top dsm so it'd probably be easier to explain in person. Let me know if you need some help or just want the entire thing done for you. basically make 2 boxes with no faces on them..make a cardboard cut out of the back of the trunk..cut the piece of wood out tracing the cardboard...attach the boxes side that doesnt have the face upwards to the big piece thatu cut out..then cut the holes for the sub........what do u do to hold the big top piece up... i know of a few ways but how is urs done (this is just for future reference if i help build one or somthing for a friend)
TBSpyder
07-03-2004, 12:51 AM
The sub box is what holds the top plate up...like a pedestal.
Kirk
07-03-2004, 06:02 AM
Beleive me..... keep your trunk space :lol:
I had to have mine made as low as possible so my targa top fits back there, and so i still retain my normal trunk space. In exchange I had to get rid of my spare tire. The top is just a plate... which over my sub/amp box (which are seperate...).. it fits snug around the trunk area so theres no play, but its easy to take out... ill show you pictures to give you an idea
Kirk
07-03-2004, 06:09 AM
warning.. shittiest quality pics to mankind.
this is just the sub box, formed around the spare tire well.
http://www.tamparacing.com/forums/attachment.php?s=&postid=799963
amp rack bolted up to it
http://www.tamparacing.com/forums/attachment.php?s=&postid=799968
http://www.tamparacing.com/forums/attachment.php?s=&postid=799976
Kirk
07-03-2004, 06:13 AM
rack with blocks/cap bolted up
Kirk
Kirk
07-03-2004, 06:14 AM
top plate fitted over both
TIM TIM TIM
07-03-2004, 11:14 AM
that looks pretty nice kirk :bigthumb:
TIM TIM TIM
07-03-2004, 11:17 AM
The sub box is what holds the top plate up...like a pedestal. so basically u cut the big top piece out tight so it fits in there snug then the boxes hold it from fallin to the bottom? thats less complicated then i was thinkin haha
Kirk
07-03-2004, 12:06 PM
Yea its not too hard at all... when you see it it looks more complicated than it is
TBSpyder
07-03-2004, 01:28 PM
Basically. Just make the box underneath the height you want the top plate to sit flush with. Make your template as close as possible, you'll probably have to trim here and there to get it perfect...so start out bigger and work your way down. Use a heavy box carpet on the top plate and that should cover up and small gaps pretty efficiently.
TIM TIM TIM
07-03-2004, 02:33 PM
yeah i have expiriance with cutting it to form the trunk with my car, its a pain and mine isnt perfect becasue we cut 2 pieces..one for the floor and one for liek 4 inches up and the trunk changes a little bit so the top one isnt perfect but its cclose enough...but yeah that sounds pretty simple really
GsEclipse02
07-03-2004, 03:03 PM
help sure...... u doing it would mean me haveing to pay and im really broke lol
krik the trunk space i have i cant really use so it dosent really matter i just throw every thing n the back seat dosent seem to hard ... i like the way ur set up is im debateing on if i should show my amp or no
TBSpyder
07-03-2004, 04:18 PM
Yeah. But think of the simplicity and ease. You wouldn't have to worry about a single thing...just drop it off in the morning, pick it up at nite, and it's all perfectly done. :lol: ;)
But I can give you some pointers, I've done quite a few installs in 2G's so I know them in and out pretty well. I did one the way you're explaining...two 12's firing up at the rear window, hatch sealed, and a amp rack holding two amps visible when you fold down the rear seat. Very clean and simple. I'd assume something similar would work perfectly for you.
GsEclipse02
07-03-2004, 10:59 PM
yea im thinking of something like that but iono if i want the amp rack were i have to fold the seats .... i like kirks set up alot ..... but how much would some thing like that cost ?? jw
TIM TIM TIM
07-03-2004, 11:37 PM
lol more then ur cheep ass needs to be paying..fix ur car before u add on!!
Kirk
07-03-2004, 11:56 PM
yea im thinking of something like that but iono if i want the amp rack were i have to fold the seats .... i like kirks set up alot ..... but how much would some thing like that cost ?? jw I highly doubt he has access to any tools that come looking remotely to mine :lol:
If you want something nice, clean, different... gotta pay up and have professionals do it... it isn't that cheap though but worth it in the end.
or you can have curtis carve ya a box.............. :lol:
TIM TIM TIM
07-04-2004, 12:21 AM
carve...literally haha, if u want ill help u tho julian, i dont do shit, youll owe me tho, liek u do for the brake job! biotch..
TBSpyder
07-04-2004, 12:27 AM
It'd be atleast a couple hundred. More depending on how complicated you want to get. I'd be willing to really work on price with you though considering you're an ahq guy.
TIM TIM TIM
07-04-2004, 12:35 AM
It'd be atleast a couple hundred. More depending on how complicated you want to get. I'd be willing to really work on price with you though considering you're an ahq guy. lol 20 bucks says his cheep ass wont do it
GsEclipse02
07-06-2004, 03:07 PM
lol 20 bucks i was j/w and yea im to broke iono i might sell my car also... not sure yet ....
TIM TIM TIM
07-06-2004, 03:19 PM
lol 20 bucks i was j/w and yea im to broke iono i might sell my car also... not sure yet .... lol and what are u going to get..
GsEclipse02
07-07-2004, 03:20 PM
a bike is all i can get im not going to drive a cavy or ne thing like that i want a R6 or something
Bumpin Expo
07-08-2004, 12:13 AM
:nerd: :lol: :cool: :mullet: Haters.
TIM TIM TIM
07-08-2004, 12:15 AM
a bike is all i can get im not going to drive a cavy or ne thing like that i want a R6 or something :lmao::lol::lol::lol: fat chance of that.. ur a :tard: if u do that
