View Full Version : Not playing burned cd's
ToRqUe
07-02-2004, 01:54 AM
jus got my cd player today.....it doesnt play burned cd's...is there a way around this or am I s.o.l ¿¿¿¿¿ its an alpine cda7897
kpr10is
07-02-2004, 08:27 AM
it has to be able to play some burned cds because that head unit plays mp3s....theres no way to make an mp3 cd unless its burned
only thing you can do is try different brand or color cds, i like the black ones
TIM TIM TIM
07-02-2004, 11:12 AM
your burning them wrong is my guess... my alpine plays them fine
TBSpyder
07-02-2004, 10:10 PM
CD-R's or CD-RW's?
ToRqUe
07-03-2004, 04:46 PM
cdr's
TBSpyder
07-03-2004, 05:48 PM
Something is wrong. That deck is capable of playing burned cd's. I'm guessing it's either the format you're burning them in or some sort of setting on the deck. Have you tried a different brand of CDR's?
When you burn them make sur you burn them as AUDIO CD format and not DATA CD with just MP3's on it..
TIM TIM TIM
07-03-2004, 08:41 PM
i burned mine as data files and they played fine... i think he just needs to practice up on the burning program...make sure u dont have it set to "Test only" on the program... mine was set liek that and so the cd's wouldnt play
Originally posted by whtmustangt99
i burned mine as data files and they played fine... i think he just needs to practice up on the burning program...make sure u dont have it set to "Test only" on the program... mine was set liek that and so the cd's wouldnt play because you have a CD player which is capable of reading actual MP3's....... when you burn a CD to Audio format you are lmited to 70 minutes, and the program while its burning it converts it to WAV format.... so its not an MP3 when its on the CD. If you just use MP3 on a data CD on a unit that doesn't suopport mp3 files... then that would not work.
TIM TIM TIM
07-04-2004, 12:37 AM
i wasnt sure if his model was above or below mine since mines closer to the crapy-er side of alpines things.. but still teh test only thing, if your program has that make sure u have it set to burn and not test, cuz liek i said, it wont work.... o and do the cd's play on other cd plaers?
stangerang
07-04-2004, 04:04 AM
my freinds alpine plays burnt cd's, half the time, and it doesnt let you switch between songs........
alpines are weird, it can prolly recognise mp3 format only, and not a standard audio file..........?
Derek
07-05-2004, 06:04 PM
thad be really silly
ToRqUe
07-07-2004, 04:01 PM
changed disc format from audio cd to.......mp3 cd n it worked ....weird
thanks for the help
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
