PDA
View Full Version : crossover settings?
psycho
06-28-2004, 02:55 AM
ok so i want to wire my components and obviously there are 3 ways to do so. 1st, input to low pass and output to speakers. 2nd, input to low pass and high pass from the same channel of amp, output to speakers and adjusting the crossover to "biwire". 3rd, input to hi and low pass from different amps and adjusting the crossover to bi-amp. now i have a 4 channel amp to power the components and a set of 6x9's. would i notice any difference if a wired it as biwire over wiring it with only low pass input? why?
TBSpyder
06-28-2004, 10:12 AM
Not really sure what you're explaining...but the normal way would be to run your amp at full range, output to an external x-over and then onto the tweet and mid.
SSpiro
06-28-2004, 01:34 PM
Yeah.. the initial post is kinda rough..
kpr10is
06-28-2004, 01:45 PM
Forget the stereo, invest in writing and english classes :lol: jfwy
psycho
06-28-2004, 04:07 PM
Originally posted by kpr10is
Forget the stereo, invest in writing and english classes :lol: jfwy SCREW english, i hate it :mad: . I just came form a stereo shop, he told me it was his first time to see that kind of crossover! i guess it's time to do the wiring both ways and see what's gonna happen.
psycho
06-28-2004, 04:43 PM
oh great, here is a link that explains it all, so no body will bug me about english ;)
click here (http://www.mbquart.com/scripts/mbtech.cfg/php.exe/enduser/std_adp.php?p_sid=5Pii-2fh&p_lva=64&p_faqid=12&p_created=1017857349&p_sp=cF9ncmlkc29ydD0mcF9yb3dfY250PTkmcF9zZWFyY2hfd GV4dD1jcm9zc292ZXImcF9zZWFyY2hfdHlwZT0zJnBfcHJvZF9 sdmwxPX5hbnl_JnBfcHJvZF9sdmwyPX5hbnl_JnBfY2F0X2x2b DE9fmFueX4mcF9zb3J0X2J5PWRmbHQmcF9wYWdlPTE*&p_li=)
TIM TIM TIM
06-28-2004, 04:48 PM
well if u have 4 channels run it all seperate but if u only have 2 i would say the bi wire way it says its a little better right? (just skimmed threw) cant hurt to try them both out
psycho
06-28-2004, 04:58 PM
yeah true, i have a 4ch abut i have 6x9's also. I'll do the biwire, but i dont feel like wiring the whole thing again (since the crossovers are in the front), am going to split the wire for the other input and tell you if there is any improvement.
Derek
06-28-2004, 05:09 PM
Do it the regular way. Your just gonna end up wasting wire .
psycho
06-28-2004, 05:50 PM
yeah that's what i thought and thats why am going to split the wire or connect both of the inputs together. that should be the same except for the fact that it isn't going to be concidered as a bigger gauge wire.
psycho
06-28-2004, 07:41 PM
wooow, all i did is connecting the inputs together and setting the jumper at "bi-wire" and it actually sounds MUCH cleaner at higher volumes, which enables you to give it more power. Basically, the speakers sound cleaner and louder. thanx for all of your openions :D
SSpiro
06-29-2004, 05:51 AM
Hence the purpose of a crossover..
