PDA
View Full Version : Stage 2....has been out
ACR2NV
04-29-2004, 09:24 PM
Over a week now :D
http://www.srtforums.com/photopost/data/500/1102931p4220095-med.jpg
whos waiting for theirs still?
southeastrt
05-01-2004, 07:19 PM
thats a bunch of parts. think they finally got around to putting stg 1 kit on the 2004 models from mopar. saves some work anyway.
john
CodyBinks
05-04-2004, 03:41 PM
i dont understand turbo... point me in the right direction please.... aka what are stage 1 and 2 excetera.....
southeastrt
05-04-2004, 06:37 PM
The Stage 1 Turbo Kit for the SRT-4 boosts power to 240 hp and 260 ft-lbs. of torque.
COMPONENTS:
-Stage 1 PCM
-(4) 577 cc/min fuel injectors (2003 kit only)
CALIBRATION FEATURES:
-Increased WOT and part throttle boost
-Improved turbo response
-Boost hold feature during WOT shifts
-Enchanced 1st gear boost schedule for high-performance launch
-More aggressive exhaust note during deceleration
-Optimized calibration for Mopar Performance Blow-Off Valve Conversion Kit (P4510548)
The Stage 2 Turbo Kits for the SRT-4 and PT Turbo give you a power boost of 265 hp and 280 ft-lbs. of torque on premium pump gas. For the SRT-4, you can also achieve 280 hp and 300 ft-lbs. of touque on 100+ octane unleaded racing fuel. For addition power and a more aggressive exhaust note, you can add our new Cat-Back Exhaust Systems(P4510461).
-Stage 2 PCM
-Turbo toys (SRT-4 only)
-Turbo Intercooler Sprayer
-High Octane Fuel Switch
-Dial-A-Boost "Down" Switch
-All necessary wiring, switches and mounting hardware
-(4) 682 cc/min fuel injectors
-Wastegate actuator
-3.0 Bar MAP sensor
-3.0 Bar TIP sensor
FEATURES/BENEFITS
The SRT-4 Stage 2 Turbo Upgrade Kit with Turbo Toys includes a Stage 2 PCM, Wastegate Actuator (P350), 3.0 Bar MAP Sensor, 3.0 Bar TIP Sensor, (4) +30% Fuel Injectors (682 cc/min) and Turbo Toys(Intercooler Sprayer, High-Octane Mode Switch, and Dial-A-Boost Switch).
The Performance Ratings for the SRT-4 Stage 2 Turbo Upgrade Kit with Turbo Toys is 265 hp/280 ft-lbs and 280 hp/300 ft-lbs in High Octane Mode.
The SRT-4 Stage 2 Turbo Upgrade Kit without Turbo Toys includes a Stage 2 PCM, Wastegate Actuator (P350), 3.0 bar MAP Sensor, 3.0 bar TIP Sensor,and (4) +30% Fuel Injectors (682 cc/min).
The Performance Ratings for the SRT-4 Stage 2 Turbo Upgrade Kit without Turbo Toys is 260 hp/280 ft-lbs.
