PDA
View Full Version : S10 airbag question
Domestic Disturbance
04-28-2004, 12:17 PM
how hard is it to install a basic airbag system into a chevy s10? a friend of mine may be getting a kit and he wanted to know if its one of those things the backyard mechanic can do with the right tools, or do most kits require welding/cutting?
Whaazup17
04-28-2004, 10:22 PM
evan talk to me tomorrow about this
if it is an air ride kit
the rear is pretty simple
it is the front that is giving problems. you have to plasma cut a not so the lower control arm can fit
ask me tomorrow or i'll bring it up
-garrett
04-29-2004, 12:30 AM
yeah, its actually for bubba, not me.....and does it have to be a plasma cutter or can a simple torch work?
Whaazup17
04-29-2004, 07:08 AM
plasma cutter you have to notch out the frame if you want to go low or the control arm will hit
like I said the rear is easy. you have to take the leaf springs out
and in the same mounts you put the rods to the link suspension
and in the middle of the axle you put a triangler fixture for the middle
and install the bags, install shocks in the middle
don't forget because you are getting all this suspension play that you didn't have before you are going to have to make the brake lines longer, bleed the brakes again.
and that is only the rear
the front you have to take the brake assembly completly off, remove some of the plastic, notch out the frame so the bag doesn't hit, install shocks, I belive in the kit they provide you with new control arms (you are going to have to use new control arm) and then just install everything back.
hope this helps i'll tell you about it tomorrow
-garrett
Whaazup17
04-29-2004, 07:10 AM
-garrett
sorry it isn't the control arm it is the air bag itself
cause it has a wider diameter than the spring
-garrett
Whaazup17
04-29-2004, 07:12 AM
http://www.airride.com/productinfo/airbars10.asp
this is the only kit I know about that doesn't require a c-notch
this is for the rear and it is $990
Whaazup17
04-29-2004, 07:18 AM
or you can tell him to do this
and this WILL lay his truck on the ground
http://www.airride.com/productinfo/roadgrater.asp
that you just replace the whole rear end
-garrett
