PDA
View Full Version : which wastegate??
luderacer
04-25-2004, 06:34 PM
what is a good waste gate. i am planning on running between 9-12 lbs on my honda prelude. i have a t3/t4 turbo but not installed. and what size spring should it have? thanks
-joe
luderacer
04-25-2004, 08:25 PM
anyone ?
kender
04-29-2004, 08:15 PM
I have heard tial is one of the best. I have a tial ( not yet installed) but I got opinions for about a month before I got it.
as for the spring it really depends on if you are running a boost controller or not. If you plan on running 9lbs at the lowest then I would get a 7lbs spring and run an electronic boost controller such as the blitz sbc id. If you don't plan on a boost controller then you want to get the spring for what ever boost level you want to run all the time.
I say go with a boost controller.
99B16Si
04-30-2004, 12:15 AM
go with a tial 38mm for 40mm depending on the flange u use
luderacer
04-30-2004, 11:33 AM
actually the mani i bought came with a 35mm tial with a 12lb spring. where would i buy a smaller spring like 8-9 lbs.?
-joe
