PDA
View Full Version : Anyone know where I can get one of these today or tomorrow?
Chris
04-22-2004, 02:56 PM
I might break down and try to make one since I have a -4 to 1/8 pipe thread fitting...... but it would be nice to just pick one up.
Thanks,
Chris
Chris
04-22-2004, 03:11 PM
should be like this I believe.....
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-FLA-008&Category_Code=OIL
Alan
04-22-2004, 04:53 PM
Try contacting Dave (ForceFed23). He usually has spare turbo parts or knows where to find them in a pinch.
Just Dave
04-22-2004, 06:46 PM
I just used a pipe thread elbow for mine. I don't have a stock one laying around though.
NChatch
04-22-2004, 07:27 PM
go to ACE hardware, or lowes
qitstrn
04-22-2004, 07:56 PM
Give glen a call at hybrid performance he has alot of turbonetics stuff
Chris
04-23-2004, 10:50 AM
Looks like I'm just going to tap it guys, thanks...
99B16Si
04-23-2004, 12:23 PM
if your in tampa...united speedworld on florida ave in between bearss and fletcher or in your in pinellas Automotive engineering
Chris
04-23-2004, 12:25 PM
Thanks, but I doubt either of those guys would carry parts like that... have you ever picked up turbo parts from those guys before?
Just Dave
04-23-2004, 12:31 PM
Its not already tapped Chris?
Chris
04-23-2004, 12:42 PM
no it's not :(
I'll just have to treat it like tapping an oil pan and be really carefull about it....
99B16Si
04-24-2004, 11:17 AM
why dont u just screw the fitting directly into the turbo??
if for some reason u can, theyre real easy to make with the right tools. i can do it if necessary
0HP930
04-24-2004, 11:26 PM
If you have not already done this and no one has already shown you the trick, put a bunch of heavy grease on the tap before you use it to contain all of the tap shavings.
Sam@Coastal
04-25-2004, 08:03 PM
if you havent figured it out yet chris i can cut you one if you really want to use the flange, we usually just tap the feed lines in most cases, i dont recommend tapping the return though IMO its not enough volume to tap the return for a 3 or 4 AN fitting, i usually cut a thick flange and tap it for a big hose barb of a size to my liking.
Chris
04-26-2004, 09:42 AM
It's all done guys, I tapped it Saturday morning, and it works fine....
