PDA
View Full Version : How hard is it to install an alarm?
Bumpin Expo
04-05-2004, 09:55 PM
Well I was whoring ebay and I found there is a lot of alarms that go dirt cheap. I was thinking maybe I could buy the and if only I knew how to install them I could really make osme good money off of this. People would pay some decent money for one of these to be put in. So exactly how hard would it b to try to install one?
Kirk
04-05-2004, 10:43 PM
Oh man I gotta see this...
Bumpin Expo
04-05-2004, 10:44 PM
muahahha
so how hard is it guys? anyplace online thats "alarm installs for dummys"?
TBSpyder
04-05-2004, 11:14 PM
Doesn't www.installdr.com have alarm wiring diagrams? Without a wiring diagram for the specific vehicle...you're basically screwed. It's not the easiest thing in the world.....
Bumpin Expo
04-05-2004, 11:20 PM
nothing is really the easiest thing in the world. You just gotta b able to learn how to do it
SSpiro
04-06-2004, 08:08 AM
Alarms are not for the beginner... can get pretty involved.
Once you have quite a few installs under your belt, just like with anything else, it gets easier.
TBSpyder
04-06-2004, 10:26 AM
Wiring up an amp is the easiest thing in the world compared to wiring up an alarm. Like SSpiro said, it's very in-depth. I wouldn't even attempt it without a detailed wiring diagram and someone with a little experience to guide you.
Kirk
04-06-2004, 09:26 PM
I can get yuo the wiring diagram for any make/model.. and where each wire is located... but I am not liable for when you fry your car's electrical system. Let me know the info on your car.
Bumpin Expo
04-06-2004, 09:40 PM
1999 ford explorer sport SOHC
power everything, power windows power door locks power all kinds of shit
I have a few more questions
how hard would it b to install one of those keyless entries on a car that isnt automatic door locks
Kirk
04-06-2004, 09:48 PM
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow |+ |ignition harness |
| STARTER|red/lt. blue |+ |ignition harness |
| IGNITION|green/purple *1 |+ |ignition harness |
| ACCESSORY|gray/yellow *1 |+ |ignition harness |
| SECOND ACCESSORY|black/green |+ |ignition harness |
| POWER LOCK|pink/yellow |- |driver's kick panel |
| POWER UNLOCK|pink/green |- |driver's kick panel |
| LOCK MOTOR|pink/black | |driver's kick panel |
| UNLOCK MOTOR|red/orange | |driver's kick panel |
| DISARM DEFEAT|pink/orange *2 | |driver's kick panel |
| PARKING LIGHTS +|purple/white *3 | |driver's kick panel |
| PARKING LIGHTS -|white/purple | |driver's kick panel |
| HEADLIGHTS|red/yellow |+ |light switch |
| DOOR TRIGGER|black/lt. blue *4 |+ |driver's kick panel |
| DOME SUPERVISION|black/lt.blue |+ |driver's kick panel |
| TRUNK/HATCH PIN|common with doors | | |
| HOOD PIN|tan/lt.green |- |driver's kick panel |
| FCTRY ALARM ARM|arms on lock *5 | | |
|FCTRY ALRM DISARM|dk. green/purple |- |driver's kick panel |
| TACHOMETER|tan/yellow | |PCM *6 |
| SPEED SENSE|gray/black |8 |PCM *6 |
| BRAKE WIRE|lt.green |+ |driver's kick, brake switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|wht & dk.blu/org *7 |+ |wiper motor or relay |
| LF WINDOW UP/DN|wht/blk - red |A |at motor in dr door |
| RF WINDOW UP/DN|wht/yel - tan/lt.blu|A |sw dr door or dr kick |
| LR WINDOW UP/DN|gry/org - yel/lt.blu|A |sw dr door or dr kick |
| RR WINDOW UP/DN|yel/blk - red/blk |A |sw dr door or dr kick |
| POWER ANTENNA|lt green/purple |+ |radio |
Notes:
NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start. *1 Two wires each at switch, both are common, only need to power 1 each during remote start. *2 You may also use the pink/green power unlock wire. *3 Also found to be white/black at the rear of the switch. *4 To avoid the dome light delay and dome light time-out use the separate door triggers. In the drivers kick panel find yellow/black for the drivers door, lt. green/yellow for the drivers rear door, and white/purple for the rear hatch. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All five wires are negative trigger and must be diode isolated together. *5 Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm. *6 The PCM is located at the top of the firewall towards the passenger side, the tan/yellow tach wire is also found at the back of the instrument cluster. *7 Also found yellow/white (-) at the firewall connector.
TBSpyder
04-07-2004, 04:48 PM
Automatic door locks? As in "power" door locks?
In that case, you'd have to do a manual to power conversion in order to use a keyless entry.
Bumpin Expo
04-07-2004, 05:34 PM
how hard would it be to do it? same as alarm? god i need to do my homework!
Kirk
04-07-2004, 08:52 PM
Its not hard... just buy a damn kit....ebay!!
Bumpin Expo
07-13-2004, 10:02 PM
BACK FROM THE DEAD I KNOW
Kirk Can I get a diagram for a 95 Honda Del Sol?
What do you think would be easier to attempt for the first time? Basic python alarm or a remote start system?
Viper4ug
07-13-2004, 10:07 PM
IVE BEEN INSTALLING ALARMS FOR 8 YEARS ITS A PEICE OF CAKE AND I CAN DO IT WITH MY EYES CLOSED ANYONE WHO WANTS ONE INSTALLED HIT ME UP I WILL DO THE INSTALL FOR 99.99
813-598-6046
AS FOR SOMEONE WITH NO KNOWLEDGE OF INSTALLING ALARMS DOING IT,,,, OMG LMAO GOOD LUCK AND HATE TO SEE THE LAW SUITS FOR ALL THE VEHICLES YA DAMAGE! LMAO
Kirk
07-13-2004, 10:21 PM
813-598-6046
WE CAN SEE YOUR TYPING JUST FINE
And yes... I have a diagram for the Del Sol.. first tell me why you need it... if you are planning on installing someone's alarm then I am not giving it to you. :lol:
Bumpin Expo
07-13-2004, 10:26 PM
blah some help u guys are
SSpiro
07-13-2004, 10:52 PM
The internet is your friend.
TBSpyder
07-13-2004, 11:58 PM
IMO, remote start is easier than a full feature alarm system.
TIM TIM TIM
07-14-2004, 12:20 AM
your crazy... that shits to complicated for me to even wrapped up in
Bumpin Expo
07-14-2004, 12:25 AM
how much easier? Kirk, can you send me a chart like u did for my explorer or it? I want to try either an alarm or remote start. ive always wanted to be able to install something like that
93ex
07-14-2004, 03:27 AM
kirk, email me a chart, jreade@tampabay.rr.com or holla on aim
97 blazer 2 dr
SSpiro
07-14-2004, 08:43 AM
Hey Kirk.. hook me up too for a 2000 Jeep Grand Cherokee, I6, 2WD. sspiro@tampabay.rr.com ;)
Bumpin Expo
07-14-2004, 12:33 PM
alarm install contest, person with the less mess ups and accually installs one that works wins
GsEclipse02
07-14-2004, 02:46 PM
.lol im telln krista not to let u do this to her poor lil car lol.... is the sub there yet ??
Kirk
07-14-2004, 07:19 PM
alarm install contest, person with the less mess ups and accually installs one that works wins first a hole through a gas tank, now fucking up someone's wiring harness? :lol: ;)
I'll send you guys the diagrams you requested tonight.. am a little busy right now
93ex
07-14-2004, 07:27 PM
thanks kirk we love you
eli
07-14-2004, 07:58 PM
i think afboy should check his pms :) i need those fans :)
Bumpin Expo
07-14-2004, 08:56 PM
OMG ELI, i so didnt see those. I dont check my pms and TR doesnt alert me when I get them so I forget! This sat im going to the car show and maybe showing my explorer off for a lil for shits n giggles. if u wanna meet up then ill b there. and eli my cell is 433-6452. Feel free to call netime, or grls wit big tits u know can call too.
Kirk, u hurt my self esteem. Sigh
And yes julian I got the sub in
joebobclark
07-14-2004, 09:22 PM
I put in a full feature alarm (remote start, starter kill, etc.) into my 95 Civic about a month ago. Wasnt too bad.
I had to do it cause no one I could find would hook up the remote start on my 5 speed.
Decided to power the locks too while I was at it. It easier to add power locks when you install a keyless entry alarm, rather than doing the factory conversion first.
I was thinking of doing this too, seeing as most Remote Start alarms start around $400 installed and I got my eBay "special" for $89.99. But Im just too fuking lazy.
Good luck. Take your time, and dont get scared of it before you start.
Chris
eli
07-14-2004, 09:56 PM
thanks man, ill meet u at the car show.
Kirk
07-14-2004, 10:16 PM
Jessie - you have mail
Bumpin Expo
07-14-2004, 10:39 PM
jessie has mail and i dont wow
joebob thanks man im going to try remote start
Kirk
07-14-2004, 10:41 PM
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|green/white |- |drivers kick panel *1 |
| POWER UNLOCK|green/red |- |drivers kick panel *1 |
| PARKING LIGHTS +|red/black | |green connector at fusebox |
| HEADLIGHTS|red/white |+ |headlight switch |
| DOOR TRIGGER|green/red |- |low in drivers kick |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green/black |- |blue connector above fusebox|
| TACHOMETER|blue *2 | |2-pin plug near distributor |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER| | | |
| WIPERS| | | |
| LF WINDOW UP/DN|blu/red - blu/wht |A |behind carpet on pass. |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |side of console |
| LR WINDOW UP/DN|red/yel - red/blu |A |(rear window) |
*1 Door lock module in door. Remove silver cruise module in drivers kick panel and pull door harness out to access 20 pin plug. Lock wires on door side of plug. *2 Also at round gray connector next to hood strut.
93ex
07-15-2004, 03:46 AM
omfg its jesse!!!!!!!!!!!! thanks
Kirk
07-15-2004, 06:23 AM
The one i just posted was for the del sol that is not going to work anymore, just so nobody gets confused
GsEclipse02
07-15-2004, 03:35 PM
i see it now ....... curtis having to sell his audio shit cuz he fryd all of kristas wires and shit lol
TIM TIM TIM
07-15-2004, 05:40 PM
lol im going to laugh when he installs the alarm and is all happy..then he sets it and opens the door and it does nothing...
Bumpin Expo
07-15-2004, 06:26 PM
and im going to laugh when I get it right, kirk oh well I went to CC and got a chart and some pointers on how to get 'er done
GsEclipse02
07-15-2004, 06:37 PM
lol hope u do get it right it sucks haveing to fix shit and pay for shit to get fixd ....
Bumpin Expo
07-15-2004, 06:53 PM
TRUST ME I know
Viper4ug
08-17-2005, 03:11 PM
hehe still trying to install alarms huh, ever thought about going to school for it, they actually have a certification class you can take that would be cheaper than installing an alarm and watching the cars burn to the ground, trust me ive been doing it for ever and have seen many owner installed alarms that have a caught fire, or b fried the ecu in the car or c messed up the wiring harness for the ignition and what not, not to discurage ya but if you really wanna do this please get certified and do it right so you dont end up being sued for everything you have when you put an alarm in a car and the poor ladys car catches fire with her kids in it etc....
MY1950COUPE
02-18-2006, 01:02 AM
Guess he burned up his car, No more posts
SickVette
02-18-2006, 01:39 AM
Car alarms take a sound working knowledge of a vehicles electrical system. Installer also needs to be familuar with usind relays, resistors, and diodes. WIth the massive amount of ECM or BCM controlled items in todays autos it is very important to stay away from test lights and know what it is going on with those units. Older cars are alot easier to install an alarm in and less likely to damage anything. Newer cars can get very complicated. It does not take much to burn up a window switch or door lock control module. I have seen plenty of blown ECM's also. I have been installing alarms professionally for 16 years and have installed several thousand of them. If someone wants a hand or pointers let me know. I can at least get you started in the right direction to help the install go much smoother.
