Billy
04-01-2004, 01:13 AM
Knitting Basics
How To Knit
http://www.craftown.com/knitle1_small.jpg
CO = Casting On
Make a slip knot on the needle about two yards from the end of the yarn. (This amount varies according to the number of stitches to be cast on, but always allow plenty!) Holding needle in right hand, loop end of yarn around left thumb and hold it in the left palm. Insert tip of needle into loop on thumb, pass yarn leading to the ball around needle from back to front, draw yarn through loop. Slip loop off thumb and tighten stitch thus formed on needle.
Knitting
http://www.craftown.com/knitle2_small.jpg
K = Knit
Holding needle with cast-on stitches in your left hand and second needle in your right, with yarn at back insert tip of right-hand needle into the first stitch from left to right, front to back. With right hand, pass yarn under and over tip of right-hand needle, draw yarn through stitch, and slip stitch just worked in off.
Purling
http://www.craftown.com/knitle3_small.jpg
P = Purl
Holding needle with stitches in your left hand and second needle in your right, with yarn at front insert tip of right-hand needle into first stitch from right to left, back to front. With right hand, pass yarn over and under tip of right-hand needle, draw yarn through stitch, and slip stitch just worked in off left-hand needle.
Increasing
http://www.craftown.com/knitle4_small.jpg
Inc = Increase
Work the stitch as usual but do not slip the stitch just worked in off the left-hand needle; work again in the same stitch inserting the needle into the back of the stitch. Now slip the stitch worked in off the left-hand needle.
Another method of increasing is to knit one stitch in the back of the stitch in the row below, then knit the stitch above as usual.
Decreasing
http://www.craftown.com/knitle5_small.jpg
Dec = Decreasing
If knitting, insert tip of right-hand needle into second stitch on left-hand needle, then into first stitch; work the two together as one stitch.
http://www.craftown.com/knitle6_small.jpg
If purling, insert tip of right-hand needle into first stitch on left-hand needle, then into second stitch; work the two together as one stitch.
SL 1, K 1, PSSO
http://www.craftown.com/knitle7_small.jpg
SL = Slip K = Knit PSSO = Pass Slipped Stitch Over
Slip stitch from left-hand needle to right-hand one without knitting it. Knit the next stitch. Insert tip of left-hand needle into the slipped stitch, pass it over the knitted stitch, and off needle.
Yarn Over
http://www.craftown.com/knitle8_small.jpg
YO = Yarn Over
If knitting, bring yarn to front of work, over right-hand needle to back, and then knit the next stitch.
http://www.craftown.com/knitle9_small.jpg
If purling, wind yarn completely around the right-hand needle from front to back. and then purl the next stitch.
Casting on during work
http://www.craftown.com/knitle10_small.jpg
Turn work so needle to which yarn is attached is held in left hand. Insert tip of right-hand needle into first stitch, pass yarn under and over and draw it through stitch; leave stitch worked in on left-hand needle.
http://www.craftown.com/knitle11_small.jpg
Transfer new stitch from right-hand needle to left-hand, needle. Repeat for the required number of stitches, then turn work again and continue as the directions specify.
Binding Off
http://www.craftown.com/knitle12_small.jpg
Work the first two stitches as you would in a regular pattern row. * Insert tip of left-hand needle from left to right into first stitch worked. Pass first stitch over second stitch and off right-hand needle. Work the next stitch and repeat from *.
Continue practicing these basic techniques until you have found a comfortable tension and your work looks even. You may then try a simple knitting project. If you are pleased with the results then you will be ready for more advanced projects. Happy Knitting
How To Knit
CO = Casting On
Knitting
K = Knit
Purling
P = Purl
Increasing
Inc = Increase
Decreasing
Dec = Decreasing
SL 1, K 1, PSSO
Yarn Over
YO = Yarn Over
Binding Off
