PDA
View Full Version : amp is cutting out...
Solar Specialist
03-26-2004, 09:43 PM
Well I installed my system like 3 weeks ago and I've had no problems at all with the amps, except the tweeters were cutting out some times on my components. Now I get in my truck and the stereo worked, turn it up a little bit and the amp cuts off and the red light on it comes on which I assume is the protect light since its too dark to really tell right now. So what can be going on besides the amp being messed up?
eli
03-26-2004, 09:47 PM
u check ur fuses?
Solar Specialist
03-26-2004, 09:58 PM
If it were the fuses the amp wouldn't work at all. It still works when I turn the stereo off and back on again and keep it down. But if I turn it up the amp goes out again.
TBSpyder
03-26-2004, 10:13 PM
I double check all your wiring, make sure it's all correct and secure. Is the amp hot to the touch?
Solar Specialist
03-26-2004, 10:28 PM
Not even warm. But if my wiring was wrong wouldn't something have messed up 3 weeks ago? Nothing has changed at all. And I know for a fact nothing is in the wrong place. I was the only one involved in the install and wiring what I did was simple.
TBSpyder
03-26-2004, 10:34 PM
What kind of amp is it?
kpr10is
03-26-2004, 10:37 PM
How high do you have the gains turned up?
MDIFYTD
03-26-2004, 10:42 PM
Make sure the amp is stable at the ohm load you're running. If so try turning the gains down and see if the problems persist. There might also be a speaker wire grounding somewhere.
Solar Specialist
03-26-2004, 11:15 PM
Ok, its a profile 4 channel amp running at 4 ohms. I turned the gains down already. I am thinking of taking this amp back and getting something else actually. I want something louder anyways and this thing is giving me problems. Anyone have any suggestions for about $200-250? I want a clean amp that will put out pretty close to 100rmsx4.
eli
03-28-2004, 09:30 AM
talk to wshmoer on the boards hes got a bitch load of amps, his aim is dub tre 3, tell him eli sent u.
Solar Specialist
03-28-2004, 01:52 PM
Well I was going to get it from thezeb.com since I am returning my current amp to them and will have a credit. I'm looking into rockford amps, are they clean for highs?
TBSpyder
03-28-2004, 08:50 PM
RF is decent. Much better than Profile.
Solar Specialist
03-28-2004, 09:31 PM
Well before my amp started cutting out my tweeters were cutting out when I turned it up I think because the amp isn't very clean. If I spend more I want to be sure its a good amp is all. I don't want to have to worry about anything cutting out. My girl's power acoustik doesn't do that and its old as hell.
HAVIK
03-28-2004, 11:19 PM
its called clipping. An amp will do this if a speaker is grounded , wrong ohms load, or if the gain are set to high and it causes an overload. It send it into a protection mode. Did you turn up you amp gains?
TBSpyder
03-29-2004, 10:48 AM
I think he said he turned the gains down already...
Solar Specialist
03-29-2004, 11:26 AM
Ya I turned the gains all the way up with the stereo all the way up. Then I turned the gains down until the amp would stay on and left them there. Turned out to be only about 1/3 the way up. Now I'm looking into new amps, probably a RF.
Domestic Disturbance
03-31-2004, 11:46 AM
why a RF? its my expieriance that anything that can be purchased at Best Buy's car audio department is not as good as it gets
93ex
03-31-2004, 12:50 PM
and not everythign rf is sold at best buys car department.. pioneer is sold there too..but the permier stuff is good...
Solar Specialist
03-31-2004, 07:40 PM
Personally I think most Pioneer HU's are pretty nice. And the amp I am looking at getting is the 801x:
http://store.yahoo.com/millionbuy/roc801x.html
Is it any good or no? I can't find any decent amps for less than $300 that put out a good clean 100rms x 4 or more.
