View Full Version : what did you do to stop rattaling?
CantInjaDisNinja
03-17-2004, 08:47 PM
I was a cheap way to stop my rattaling. First off my rear deck rattles like a mofo, also my trunk rattals like a mofo. If i put the slightest downward pressure on my trunk lid a lot of the rattaling goes away.....I just want to stop all the damn rattlling and i want it to be as cheap as possible!
TBSpyder
03-17-2004, 09:20 PM
Weld it shut.
what didnt i do
carpet padding would be real cheap
Bumpin Expo
03-18-2004, 09:13 AM
go to home depot and buy a roll of "Seal and Peel" 15$ Apply like 2-3 layers of what all rattles. Plan out a whole day to do this and have fun!
take the system out thats usually the cheapest way.
CantInjaDisNinja
03-18-2004, 06:45 PM
home depot doesent carry peal n seal. I looked..Unless I looked in the wrong section. where should it be located?
MDIFYTD
03-18-2004, 06:46 PM
I used rammat, worked very nicely.
TBSpyder
03-18-2004, 06:48 PM
You're probably not going to stop your trunk lid from rattling (if you mean the lid itself is vibrating). Been there, tried that. Your best bet is to try and find an aiming method with minimal trunk rattle or just learn to live with it.
Bumpin Expo
03-18-2004, 06:53 PM
Should be in the roofing section. Ask someone who works there if u cant find it. If they dont have it u could try calling up Lowes to see if they got it. I saw it up at the home depot on dale mabry. U could also try this stuff called expanding foam. Its like a foam that u spray and it expends and its also supposed to help dampen sound. Id have to do more research and ask some people whos done this b4 that i know and get back to u
Solar Specialist
03-22-2004, 02:53 PM
That foam stuff will help, but it gets pretty hard. At least the stuff I've used. It might be good for hard to get places, but I'm not sure what it can do for a trunk really.
the foam doesnt really dampen much.. it expands and provides pressure on all sides so there isnt rattle
HAVIK
03-22-2004, 04:50 PM
Spray on rubber. Or go to sound advice they have this spray material in a can that helps out alot
TheTotaledMustang
04-04-2004, 03:14 AM
What about useing spray on to get rid up undercarrage vibrateing right around the trunk. i went with some dynamat off ebay abd the it helped the upper part of the trunk and the lid some but it stil rattles like hell near the lower part of the trunk and undercarrage...............any suggestions?
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
