View Full Version : 97 neon help
steve33755
02-07-2004, 06:51 PM
i have a 97 dodge neoni was driving then the car shut down i have oil on the sparks plugs and on the map sensor and i replace the coil and the map sensor i did a compress test i have 180 all across it still wont start
U throwing any coded?
When you say wont start, can you be more detailed...
does it crank but not start? or is it no even rollign over?
steve33755
02-08-2004, 09:20 AM
the car turns over put i not get any spark out of the spark plugs i did have a code it said the map sen. was bad i replaced it put it not throwing any codes now.
Another thing, are you sure that you are not getting spark?
Dont mean to be a prick, but I have to ask, how did you check for spark?
How's your fuel pressure?
steve33755
02-08-2004, 10:01 AM
i put the spark plug on the melt to see if i get spark i have really good fuel pressure that kool just racking my brian i cant found out whats wrong with it
steve33755
02-08-2004, 12:58 PM
u have any idea let me know thanks
flybyuin2.2
02-08-2004, 04:19 PM
most likely a cam sensor or the crank sensor is bad
steve33755
02-08-2004, 06:16 PM
where are those two sensor at and how much do they usly run and that would cause it not to get spark
Guess thats his next step......
Make sure you dont have broken wires.
steve33755
02-08-2004, 06:55 PM
i cheack all the wires none of them are broken if some one can tell me where those sensors are that would be great
Content Relevant URLs by
vBSEO 3.2.0 RC5
