View Full Version : Oil catch can question?
Country Boy
02-03-2004, 06:43 PM
Does anyone use an oil catch can here? I see them on Ebay and I was wondering if anyone uses the "off brand" catch can instead of the Greddy unit and if it works as well for 1/2 the price. Its looks the same on the outside.
I figured I would find an answer since I guess the imports owners use them :)
This V8 sucks waaaay too much oil through the PCV :mullet:
Shaun_GST
02-03-2004, 07:23 PM
fram...walmart...3 bucks
i think its actually a gas filter but thats what i and everyone else has. works just the same
Country Boy
02-03-2004, 07:26 PM
Yeah, thats what some use... a fuel filter or an air compressor air/ water seperator. Call me strange, but looks matter :D lol I dont want some rigged up job under the hood when it all purty ;)
Alan
02-03-2004, 08:07 PM
When I was planning on turboing my Focus, I was going to install a Jaz Mini Breather. Basically it is a catch can with a breather on top. It has two inlets, so you can route the PCV and the crank case breather (usually that tube recurculating form the valve cover to the induction piping). Looks real nice...ABS plastic with a little drain valve on the bottom.
Check out www.summitracing.com . Type in JAZ in the search thing, it should pop up. There are two sizes: 1 pint and 1 quart. Hope that helped. :)
Alan
02-03-2004, 08:11 PM
Sorry, I actually purchased it from www.jegs.com.
http://www.jegs.com/photos/547605325.jpg
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2463&prmenbr=361
Country Boy
02-03-2004, 08:18 PM
Cool, thanks! But, I believe it has to be a closed unit. Is the breather inline with the inlet/ outlet or just for the oil catching dept.?
Alan
02-03-2004, 08:29 PM
It isn't in line with the inlets. The two inlets "dump" into the catch container. The breather is attached at the top.
And you don't want a closed unit. You need to let the escaped crank case pressure vent somewhere. If it goes into a closed container, I imagine it may possibly cause a mess. This is why most PCV systems either recirculate back into the intake manifold, or back in the old days it just dumped via a dump tube onto the ground. According to Tony, his new diesel Chevy truck still use this dump system.
I imagine you could use a closed system where the catch can scrubs the vaporized oil out of the air and the pressure is allowed to vent back into the intake manifold, but that still isn't a foolproof means of keeping oil buildup out of the mani.
John
02-03-2004, 08:55 PM
L00k 1|\|70 M0|2050, 7h3y h4v3 4 v4|2137y 0f 4lum1|\|um 0|\|35 \^/h1ch 4|23 4ff0|2d4bly p|21c3d 4|\|d l00k p|2377y g00d, bu7 l00k 3v3|\| 5\^/3373|2 \^/h3|\| p0l15h3d 70 4 m1|2|20|2 5h1|\|3 :D 1 |23c0mm3|\|d 4 b4ffl3d u|\|17
Country Boy
02-03-2004, 09:33 PM
What I ment by a "closed" system was that there was no breather in the system like the old school motors had a breather in one valve cover. The way the LS1/6 PCV system is setup, its a closed system meaning that both breather tubes from the valvecovers plumb right back into the intake right behind the TB and theres no breather in the system. Thats why we need some type of catch can setup to rid the intake system of oil.
Ill look into the Moroso units. I know alot of LS1 guys use the Greddy can with good results. :)
Keep it coming, I might learn something for you import folk afterall :lol: j/k :D
Jordan Y.
02-23-2004, 03:43 PM
I'm making one out of my charcoal canister. I cut the sucker in half, dumped all the charcoal, I'm going to jb weld it back together. It has two hose fittings on top that perfectly fit my breather and pcv hose, and a small hole in the bottom with plastic lattice work around it that I have a bit of the filter material that was in it ziptied around. I'm going to drill a small hole on the top to drain excess oil, mount it sideways using the stock bracket somehow.
NChatch
02-23-2004, 08:53 PM
what you can do is go to HOME DEPOT, and get some 2.5 inch pvc tubing(or larger) cut about 10inch section. then they have rounded caps you can use ovc glue to use as ends. but before you glue em on, you need to go to the plumbing section and get your correct size hose barbs and locking nuts. you can fill this tube with steel wool to catch and seperate oil for extra assurance. drill the holes, insert fittings, use some JB weld, or silicone behind them, to make sure they seal. and youre done, you can also paint it if you want to be creative.
this worked on my alcohol powered go kart for years
99B16Si
02-24-2004, 11:20 AM
this is the catchcan i run in my car, it comes with extra fittings to run off the back of a b-series honda block, and it also comes with a rubber gromet and pcv valve incase u want to re-route the vapors back into the intake for emission purposes. its made by ENDYN
Rich
02-24-2004, 11:39 AM
I dump mine to the ground. Emptying some container would probably require the removal of my UICP and maybe my battery and tray.
Billy
02-24-2004, 11:57 AM
Karl, are you making a mess now? If not don't worry about it and save your money.
Country Boy
03-11-2004, 10:09 PM
Wow... forgot about this thread :D
Im making a HUGE mess.. see:
http://community.webshots.com/photo/83875611/91603833OAyZkP
http://community.webshots.com/photo/83875611/91603876bWzmMx
I found an awesome can. Its made by Accurate Machine Works. It has a baffle and the sides have undercuts so the oil cant climb the walls. Itll be here tomorrow and Ill snap some pics of it :)
Country Boy
03-13-2004, 01:30 PM
Heres the ics of it :) VERY nice piece.
Country Boy
03-13-2004, 01:36 PM
Heres the size of it.
Country Boy
03-13-2004, 01:42 PM
Here are the undercuts to keep oil from climbing the walls of the can.
Country Boy
03-13-2004, 01:45 PM
Another shot of the inside..
Country Boy
03-13-2004, 01:48 PM
Heres the baffle in the top where it enters the can.
0HP930
03-13-2004, 02:32 PM
I have a catch can but it came with the car. From the pic you can see its about the size of a full size oil filter.
