power antenna won't work -
i'm just post whoring here - cause i just found out we had audio section.
but my power antenna doesn't work - is there a way to fix this. anyone experince with it - some dude in DSM say i should replace the motor cause maybe its blown. is there a ways to test the antenna see if its not blow- so i know its not connect to the cd player.
Did you make any changes in the wiring that might have affected it? If not, then yeah, it's probably the motor. See if you can't find a used one on www.DSMtrader.com, otherwise you could probably find one at an audio shop.
