View Full Version : stupid nitrous questions...?
ok well im wanting to play around with nitrous....
now I want a wet kit but is it posible to make a dry kit into a wet kit by useing a fuel cellinoid,the y spliter for n2o/fuel,fuel pump, and extra lines??? is this a workable idea or am I missing anything and also what controls the gas flow for the wet kit??? I would imagin there is a FPR of somsort and a fuel meter to control gas flow from the extra line on the y spliter....
let me know
thanks
art
GlacierFreeze
01-11-2004, 02:24 AM
KISS (Keep it simple stupid) (not calling you stupid hehe)
Just buy a wet kit....
Whaazup17
01-11-2004, 07:44 AM
correction you don't 'play around" with nitrous get yourself hurt....
dohc_neon95
01-11-2004, 01:20 PM
yes that is possible with the y peice jet. it has a line going into it for nos and fuel that mixes at the end of the tip. you would need another fuel solenoid, a little bit of steel line, and some how tap into your fuel line to deliver fuel to the fuel solenoid (the pressuse from the fuel pump will be eneough, you dont need another fuel pump). And u use the same pill for nos that u do to get how ever much fuel into the intake.......i.e. if u use a 100 hp pill u would most likely use a 50 "hp" jet for the fuel...and then wire the fuel solenoid to the nos solenoid so that they open up at the same time..........But to save all the bullshit and confusion u r better off spending the extra money and getting a wet kit...
cool...also Im sorry "playing around" was not a good choice of words...but the reason i ask is I can get my hands on a dry kit for around $150ish and most wet kits are about $625ish, but from what iv read so far is the fuel should be a 15% amount of the n2o...I not doubting you I was just doing some research on line and i would much rather take the word of somone local rather than somone whom I have never meet LOL on some web site....but the hook up and wiring of the kit is no big deal I just want to make sure my concept of the A/F is corect i realy dont feel like melting my pistions....and seeing as this is my first n2O engine build I would like to do it right the firs time and not the second im not one for pulling an engine any more times than i have to...
thanks and please keep the good info coming
art
drag0n
01-11-2004, 04:08 PM
First, research the size shot you want. That will tell you what size jet you need. All you need is the wet nozzel, and a fuel solonoid (don't use a nitrous solonoid they are diffrent). Tap into your fuel supply. The best thing I can think of is get 2 carb fuel filters (ones that will screw into your fuel solonoid). Cut your rubber fuel hose that runs to your fuel rail and put the fuel filters into each end. So now you have a supply for your fuel. If you need more help, just ask.
dohc_neon95
01-11-2004, 04:20 PM
the more fuel u use the better i would go at least 40% and not 15% but it all maters what shot or hp jet u are using. How much are u going to spray?? (nos jet)
tampamax
01-11-2004, 06:56 PM
Before you and these guys end up blowing your engine just go by a performance shop and ask these questions. There is way more involved than what has been asked and what has been answered.
kpr10is
01-11-2004, 07:04 PM
lol art u changed motors in the rex like they were bed sheets...not ur fault though. and r u doin this so ull keep up with jasons car once its turboed? :lmao: jk jk. anyway let me know if u go through with it cuz i wanna see ur car on spray.
good luck, and dont blow urself or ur car up
Kevin
drag0n
01-11-2004, 07:23 PM
Nitrous is not an overly complex subject. Anyone can comprehend basic nitrous useage with little problems. PM me if you have any other questions or concerns.
dragon I will probibly hit you up on the some of my ideas and kevin, jason and I are alway's going to be running side by side we tend to work on and complete projects about the same time LOL
Oya and befor i forget this is NOT I repete NOT going on a stock engine....so befor this gets to crazy I just want to throw that out there Im not the type to talk about my builds so dont ask...sorry
but I think so far I have gotten the info and resourses i need thank you all very much and I will kep checking this thread to see any more usful info
art
drag0n
01-13-2004, 03:11 PM
let me know how it goes. Ive installed countless nitrous systems, and have converted dry kits into wet ones with ease.
cool the install will be no big deal but the dry to wet I would love some help on or some helpful tip's I havnt done that convertion befor but from what i understand it all i parts....so I should have a kit in about a week but the install wont be for at least a month....
art
Cronic
01-13-2004, 10:54 PM
I want some nitrous... :cry:
tampamax
01-15-2004, 01:49 AM
i got a lot of nitrous stuff to get ride of if interested.
Sneakin Deacon
01-15-2004, 12:27 PM
yes you can turn it into a wet kit.
youll need a fuel solenoid from holley(they make the best as far as i am concerned) some steel braided lines, and you can use an NX shark nozzle (combines N2O and fuel) and if i remember correctly, some of the SOHC fuel rails have schrader valves that thread perfectly to a -4AN line. the fuel pump should keep the pressure fine. Put an FPSS (fuel pressure safet switch) so you dont squeeze with too little fuel pressure and blow. try to retard about 1 or 2° of timing per 100hp. And talk to john about getting some dyno time to check out the AF or go to like lmengineering.com(i think) and pick up a wideband o2 assembly, they run about 350...just something to make sure your in a good AF. if your worried about traction, a progressive setup (ie. 3000rpm = 35hp/7000rpm=150) might help out a little from the initial hit.
using the
Holley(NOS) specs here are the jet sizes for n2o/fuel
50 .037 .020
75 .042 .022
100 .047 .025
125 .055 .029
150 .063 .034
175 .070 .038
200 .082 .044
250 .093 .050
sneakin you are the man thanks much man this will come in very handy
art
Content Relevant URLs by
vBSEO 3.2.0 RC5
