View Full Version : Ohms question
Bumpin Expo
12-21-2003, 09:32 AM
Ok i wanna get a hifonics amp thats stable at 1 ohm. My question is what if i drop the ohm load to .6 because i wanna put 6 10's on it. What do you guys think will happen, thanks
TBSpyder
12-21-2003, 12:14 PM
I'm guessing the amp would go into protect mode and shutdown anytime you crank up the volume for an extended period of time. First question...why not just go with 2 amps? Second question...why do you need 6 10's in the first place?
I know someone with 6 10"s in his durango and it's way too much for me.. sounds like pure shit from the outside
yeah what john said, it will slam for a bit but then go into thermal and shut off or clip
assuming theyre 4 ohms why dont you just go with 4 subs?
aaron1017
12-21-2003, 01:23 PM
1ohm load is already pretty low... so a .6 load is extremely low resistance. I am guessing that a 1 ohm load on that amp for a while @ high volume will also cuase it to over-heat on a ot summer day. Also, usually with lower ohms, THD (Total Harmonic Distortion) increases...:(
Also.... 4 10"s or 12"s should be plenty.
Bumpin Expo
12-21-2003, 03:11 PM
the kid with the 10s in the durango used to go to sickles rite? the durango is pewter? i see him around its pretty loud. thanks for the help guys jus seein if one option was open
Content Relevant URLs by
vBSEO 3.2.0 RC5
