PDA
View Full Version : sub help
YellowCd5
12-14-2003, 10:34 PM
ok i have 2 12s polk and there max output is 400w a piece now my amp is a kenwood 600w what i did is i put wires and i briged them both to get power what kind of watts i and kind of amp i can use to get the most of them
93ex
12-14-2003, 10:56 PM
Questions:
1. model number on subs, whats the RMS rating on them
2. Ohm configurations
3. model number of amp
Bumpin Expo
12-14-2003, 10:58 PM
¿skirr?
aaron1017
12-14-2003, 11:29 PM
Originally posted by 93ex
Questions:
Just like Jesse, I would be glad to help you with more information. Also.... consider using some capatilization, periods, and commas in your sentences. It would make your post much easier to understand... so I don't have to assume anything.
YellowCd5
12-15-2003, 12:50 PM
ohh sorry my bad ill put the specs on today thanks for helping
YellowCd5
12-15-2003, 01:14 PM
12V Library FAQ & Advice Inside Polk
Product Registration Dealer Locator Win Speakers Contact Us
GNX124
Push It To The Limit
12 Inch, 4 Ohm Car Subwoofer
MSRP:
$159.95 each (US)*
Description & Features
Manuals
Sub Box Plans
Dealer Locator
Click to Enlarge:
[Detailed Picture]
Customer Rating:
See full reviews or submit your own
Driver Complement
Woofer
1 - 12" Diameter (30.48cm)
Electrical
Overall Frequency Response
18 - 400Hz
Nominal Impedance
4 ohms
Minimum Impedance
3.56 ohms
Power Handling (continuous)
175 w
Power Handling (peak)
400 w
Efficiency
93 dB
Voice Coil Diameter: Driver
2" (5.08cm)
YellowCd5
12-15-2003, 01:17 PM
Amp
Bridged Power Output at 14.4V (1kHz, 0.8% THD): 300
Watts x 1
Maximum Output Power: 600 Watts
Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD):
150 Watts x 2
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz,
0.08% THD): 100 Watts x 2
YellowCd5
12-15-2003, 01:18 PM
amp model kac-729s
aaron1017
12-15-2003, 03:41 PM
What exactly is your question???
YellowCd5
12-16-2003, 12:34 PM
if i got to a bigger amp what size could i use without blowing them
aaron1017
12-16-2003, 01:40 PM
Is the box sealed or ported?
If it is ported, I wouldn't go much further than the recommended 175 watts RMS rating. Maybe 200 watts maximium.
If its sealed, it should handle 250 watts.
IF YOU DO GO OVER THE RECOMMENDED RMS WATTAGE...ADJUST YOUR GAINS ACCORDINGLY!
Here is a good write-up on adjusting your gains. (http://www.altimas.net/forum/showthread.php?s=&threadid=127084) With properly adjusted gains, slightly over-powering your subwoofer should be a problem.
From the reviews (most of them crappy in nature and VERY bias) on www.polkaudio.com and a few others, these don't seem to suffer from the blowing voice coils like the Polk MOMO subs used to have in the past when they first came out.
EDIT: Forgot to say that your amp should be just fine for those subwoofers. Unless you plan on upgrading to bigger/better subwoofers in the future, just keep your amp.
93ex
12-16-2003, 03:23 PM
i think your amp right now is doing a good job.. you only have like 50 watts to play aound with so its your call
