why the fug am i loosing boost???
Old Nov 19, 2003 | 09:46 AM
Dizin's Avatar
Alive Yet Again
Default why the fug am i loosing boost???
i have all the things in my sig on my car, at higher rpm, like 5500 and up my boost drops like 4 pounds... it will peak at about 12 or 13 right at about 4000 rmp and then above 5500 its drops slowly. why is it doing that? i have the 255 fuel pump but i was gunna wait until i upped the boost.... if i put it on now will it maybe do the trick???
the thing runs which is really all that matters but i wanna know wtf is going on...
i could use the help, thanks
almost dumped 07 SI
Old Nov 19, 2003 | 11:18 AM
silvrcivic420's Avatar
single cam gsr hatch
because the t25 cant flow enough for the mods you have to have 14 psi up to redline
Old Nov 19, 2003 | 12:11 PM
psifactor's Avatar
Hello
word.
the t to small runs out around 5000rpms.
Heavy car with a 2.5L
Old Nov 19, 2003 | 01:05 PM
Ep41382's Avatar
TR Balla Donor Supreme
good ole T25 for ya.... but you say it drops to 4lbs? damn seems kinda low, mine woudl stop dropping at about 10 and would hold there.
Eric
AIM: Ep41382
Old Nov 19, 2003 | 01:13 PM
Skillionaire's Avatar
Nobody
I think he meant it would drop a total of 4 pounds. But yes, a turbo upgrade is your friend.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Nov 19, 2003 | 02:16 PM
Dizin's Avatar
Alive Yet Again
a wise person told me if i get the boost controller it will hold alot better... so up boost to??? i will eventually up to the evo upgrade but not just yet, the t isnt that bad for now...
almost dumped 07 SI
Old Nov 19, 2003 | 07:01 PM
willjs7's Avatar
No a boost controller will not let u hold the boost with that turbo. Upgrade, if goin to an evo b16g Make sure to get the adapter kit for your 2g.
Andrew-
www.autoliftplus.com
Your neighborhood do-it-yourself auto shop!
Old Nov 20, 2003 | 05:38 AM
Rich's Avatar
Old School.
You have you roughly figure that your displacement is going to draw a certain amount of air per revolution. As you multiply that revolution by thousands, you greatly increse the amount of air that the motor needs. You subtract that from what your turbo can produce, and the end result is boost. If your motor is gulping more than your turbo can produce, your boost pressure decreases.
You may know who we are, but we KNOW who you are.
Old Nov 20, 2003 | 10:19 AM
Dizin's Avatar
Alive Yet Again
thanks
almost dumped 07 SI
