View Full Version : Help on wiring!
Bumpin Expo
10-29-2003, 09:48 AM
Ok i have have 2 channel 200 watt lightning audio amp that i used to run my tweeters but i got some new infinity speakers so i want to run that amp on them. My problem is on one of the channels the posative doesnt work for some reason. I did have the amp running in one ohm by putting all the posatives into one posative and the negatives into one bridged but it got really hot because the amp isnt one ohm stable. The negative works on both chans but the posative on one doesnt work. Is there any way i can wire all 4 speakers to get a 2 ohm load or am i fuxed? Thanks guys
SOunds like you fubared an output on the amp
but for future refernace, the infinity comps shoudl have a 4 ohm total load, so running those in paralell shoudl giv eyou 2 ohm load, but you wont have any left right seperation.
Bumpin Expo
10-29-2003, 10:01 AM
i got the amp for free, the one channel has always been fubared. And yeah i kno they have a 4 ohm load but how would I wire the speakers to get a 2 ohm load? I wired all posatives to one chan and all negatives to the negative but thats a 1 ohm load. Any way i can get 2?
Bumpin Expo
10-29-2003, 10:06 AM
the x represents the messed up channel, could i like connect all the posatives to the posative that works and then 2 negatives to one then 2 to the other? would that give me 2 ohms?
ar eyou running componets, or just like 5x7's and seperate tweeters?
Bumpin Expo
10-29-2003, 10:11 AM
just 4 5x7's and there are tweeters in the middle, i just want to run all 4 speakers to that amp but that 1 posative on the channel is fucked up! grr
well, this will give you a 4 ohm load
http://www.rockfordfosgate.com/rftech/wiringwizard/4_4ohmSVC_4ohm.gif
Which terminals you want ot hook it up to its up to you, I dont know your amp, but you can always try it on the good channel, and if that doesnt work, you can try using the negative form the bad channel and + fomr the good channel to bridge it..
racingtheburg
10-29-2003, 02:37 PM
sooo thats how they do it awwww's in amasment
Content Relevant URLs by
vBSEO 3.2.0 RC5
