View Full Version : best system under 1500$
Robby
10-09-2003, 01:59 AM
since I am fully aware of the imense free time everyone has on their hands make the best system you can for under 1500$ and thats not retail. give us links to prove your prices. that ought to keep someone entertained... or this may go completly ignored. Either way I feel as if i contributed
aaron1017
10-09-2003, 12:51 PM
I would help you if you could be a little more specific on what you would like to include in your system?
Headunit?
Components?
Subwoofer?
DVD?
etc.
i think this was a "1500 dream system"
but I cant do mych for 1500
offsetillusions
10-09-2003, 02:15 PM
no shit... that would buy me an amp and a can drink
1500 = 300 for HU, 300 foramp, 500 for amp, 300 for a sub, 100 for wires
stock speakers rock on
MDIFYTD
10-09-2003, 05:19 PM
Head unit: Eclipse CD5423 (http://www.tweeter.com/product/index.jsp?productId=1264793&cp=1124466&page=3&pageBucket=0&parentPage=family) - 289
up front: CDT CL-61a (http://www.thezeb.com/caraudio/CDT_Audio_Components.html) -$149
amp for fronts: ARC 2050 (http://www.rainarc.com/cxl_2050.htm) - 269
subs: 2 Adire audio shivas (http://www.adireaudio.com/mobile_audio/drivers/shiva.htm) 125x2=250
sub amp: JBL 600.1 (http://www.sounddomain.com/sku/JBLBP6001) - 349
That's ~1300 so use the other 200 on wires and deadener...
Big-D-Bo
10-10-2003, 08:24 AM
Well i have a full system i am thinking about getting rid of not sure on price yet but if your lookin for sumthin serious pm me.
Robby
10-10-2003, 11:39 AM
Not a dream sytem... just the best you can do with that amount of money
racingtheburg
10-11-2003, 12:47 PM
Panasonic CQ-DF903U CD Receiver w/CD Changer Controls
50W x 4 Channel High Power Amplifier
MOSFET Output Stage
Sirius® Satellite Ready
CD/CD-R/CD-RW Playback
Multi-stage Noise Shaping 1-bit D/A Converter
3-beam Hologram Pickup
One-chip Digital Circuit
8x Oversampling Digital Filter
High Definition 3D Dot Matrix LCD Display
Rotary Knob
Day and Night Design Display
Slim Fit Mount
Pre-Amp Outputs (dual outputs (5V/60 ohms))
Non-Fading Subwoofer-Out, 5V high voltage with low impedance of 60 ohms
Spectrum Analyzer
Super Bright Display with Dimmer
LCD Illumination Color Blue
Button Illumination Color Blue
Super High Definition Bass
CD Changer Control: Track/Disc Scan, Search, Track/Disc Repeat, Random Play
Alphatuner V with 18 FM and 6 AM presets with preset scan
Auto preset memory with scan
FM Optimizer
Adaptive FM Front End
Impulse Noise Quieting
Muting
Attenuator
Bass, Treble, Balance Fader Controls
CD Controls: Scan, Search, Repeat and Random Play
CD Pause
AUX Input
Open Face CD Access
Removable Faceplate
Built-in Quartz Clock
Wireless Remote Control
Speaker Impedance: 4-8 ohms
Frequency Response (±1dB): 20Hz - 20kHz
S/N Ratio: 95dB
$230
Kicker RS5C 5 1/4" Component System
Titanium-plated polymineral woofer with cast aluminum basket
1" silk dome tweeter reproduce crystal-clear highs
High-quality two-way crossover (3,500 Hz, 18 dB/octave) with variable tweeter output controls provide seamless movement across the music spectrum
Kicker's mounting system lets you position the tweeters anywhere you want for superlative imaging
Frequency response: 50-22000 Hz
Power range: 8-90 watts RMS
Sensitivity: 87 dB
Depth: 2-7/16"
Package included:
Two R5c woofers
2 Grilles
2 Grille rings
2 Tweeter grilles
2 Plastic filler rings
Two R25 tweeters with attached tweeter pole mounts
2 Crossovers
2 Surface mount housings
2 Flush mount housings
2 Flush mount clips
10 Speed clips
Sixteen 1-1/4" self-tapping screws
Two 7/8" self-tapping screws
2 Machine screws
4 Red butt connectors
1 Grille removal tool
One 1.195" x 0.925" strip of dum-dum
Two 6' lengths of speaker wire (each length of speaker wire has bare wire on both ends)
Two 10' lengths of speaker wire (each length of speaker wire has bare wire on both ends)
Two 10' lengths of speaker wire (each length of speaker wire has quick-slides on one end and bare wire on the other end)
Manual
$180
racingtheburg
10-11-2003, 12:59 PM
x2 Eclipse SW-8122.4 12" Aluminum Cone Subwoofer (4 Ohms)
Santoprene Surround
Aluminum Cone
Dual Mirror-Image Spiders
Aluminum Voice Coil Former
"Bottomless" Design
Aero-Vented Pole Piece
Cast Aluminum Frame
Double-Stacked Magnet
Small Sealed-Box Enclosure
Continuous Power Handling: 500W
Music Power Handling: 1,000W
QCA (Quick Change Assembly)
$560
racingtheburg
10-11-2003, 01:02 PM
JBL BP1200.1 1200-Watt Subwoofer Amplifier
Die-cast chassis uses the entire footprint for amplifier cooling
"Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
High-frequency switching power supply is more efficient, drawing far less current from the vehicle's electrical system
Four high-level and low-level inputs facilitate constant bass, regardless of head unit fader position
Variable electronic crossover and bass-boost optimize subwoofer performance
$300
racingtheburg
10-11-2003, 01:05 PM
PowerAcoustik OV2-300 Gothic Series 2-Channel
Briged Max: 300 Watts
Mono RMS: 170 Watts
2 Ohm RMS: 85 x 2 Watts
4 Ohm RMS: 70 x 2 Watts
Super Cool Blue LED
Chrome Top Plate Panel
Full MOSFET Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18dB Bass Boost @ 40Hz.
Frequency Response: 10Hz to 30Khz
S/N Ratio:97 db
THD: 0.02%
2ohm Stable Stereo
System Distress Indicator
High/Low Level inputs With Floating Ground
4 Gauge Power/Ground Connection
Gold plated RCA Connectors
Line output
Dimensions: 7.25'' x 11.25'' x 2.25''
$70
racingtheburg
10-11-2003, 01:08 PM
Grand total of $1340 and thats with eclipse subs!!!! I would go with 2 15 inch kicker copm vr's my self or the 18's
but I think kick ass system for under 1500
offsetillusions
10-11-2003, 01:14 PM
post whore lol... Just messing
racingtheburg
10-11-2003, 01:42 PM
lol I just like pictures hahah
Robby
10-12-2003, 10:48 AM
MB Quart “Q”s qm218.61
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11022
400$
Pioneer 740mp Head unit
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13452
275$
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11947
Kicker KX 700.5
349$
http://mmxpress.com/id.html
IDQ 2ohm DVC
150$
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13576
Phoenix Gold 4G wiring kit 45$
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11705
Focal 165V component set for rear fill 229$
Great System for a grand total of 1448$
I think anyone would be more than happy to have that system. Especially for 1500$
Domestic Disturbance
10-12-2003, 07:01 PM
check this site out
http://www.avionixxusa.com/ep/products.htm
avionixx 800.2
avionixx 800.4
ED 15A
the head unit is going to be a personal preferance, but youve got a good 700 dollars to spend if you go with these amps and one of these subs
10-12-2003, 07:03 PM
and trust me, one 15a is seriously going to be enough for you
Content Relevant URLs by
vBSEO 3.2.0 RC5
