PDA
View Full Version : This Forum is SLOW!
Patrick
10-06-2003, 12:00 PM
So I figured since I'm looking to get an SRT-4, I was wondering what some pros and cons about the 2003's and 2004's are. Any info would help. Also, what size turbo do they come stock with? Thanks
cali
10-06-2003, 12:21 PM
Ok mr smart guy :D
The search button still works, but since im bored:
http://www.tamparacing.com/forums/showthread.php?s=&threadid=104569&highlight=srt4+turbo
http://www.tamparacing.com/forums/showthread.php?s=&threadid=100581&highlight=srt4+turbo
It sure aint no expedition
Cons: no lsd on 03, and oh.....its just a neon:nerd:
Pros: Everythign else.
Patrick
10-06-2003, 12:49 PM
werd, thanks...didnt say what size turbo comes stock on there though. :D
cali
10-06-2003, 04:21 PM
look again grasshopper
Patrick
10-06-2003, 04:52 PM
15g?
cali
10-06-2003, 06:21 PM
Originally posted by Patrick
15g?
The stock turbo is a td04-15gk and flows about 405 cfm maxed out.
edit for correction
ACR2NV
10-06-2003, 11:12 PM
umm no...the stock turbo is a TD04LR-16G-K built by Mitsubishi of course but what makes this unit unique is that not only is it reverse flow but also the exhaust manifold and exhaust scroll are cast as one piece.
Zate
10-06-2003, 11:25 PM
04s have LSD ?
Patrick
10-06-2003, 11:32 PM
copied from the dodge websiteNew Quaife Automatic Torque Biasing (ATB) diferential
Limited Slip Transaxle Differential
ACR2NV
10-06-2003, 11:40 PM
yes 04s come with LSD, 230hp and 250torque, aluminum (racing) pedals, sunroof option, Side impact option (deletes racing seats) and blue as an additional color to the red, yellowm, black and silver already available.
ACR2NV
10-06-2003, 11:50 PM
i forgot to mention for 2004 Dodge decided to drop the 205/50/17 Michelin Pilot Sports in favor of 3 season BFG KDW2s in 205/50/17s
cali
10-07-2003, 06:28 AM
Youre right....thats what I get for copying the morons at neonparts.
A few more interesting things about the turbo: Packaging constraints dictated a reverse-rotation turbo that spins counter-clockwise, unlike most turbos (but like the EVO VIII's). The Mitsubishi TD04 compressor has a compressor bypass valve built right into the compressor housing. The silver can on top is the diaphragm that opens the valve to vent boost from the volute (the outside of the snail) back to the compressor inlet. Both the wastegate and bypass valve get their boost signals via ECU-controlled solenoids.All together, the turbo is a Mitsubishi TD04LR-16Gk with a 6cm2 turbine inlet. This will only mean something to you if you're familiar with Mitsubishi turbos, and even then maybe it won't. Mitsubishi wouldn't cough up the compressor maps for this turbo, but we did learn that peak compressor efficiency is a very healthy 77 percent
Patrick
10-07-2003, 10:49 AM
you sure this time? hahahahaha
