87 S10 2.8L Help....
I have a 87 S10 with the 2.8L V6 in it...
The Problem I have is a oil leak...It is coming from the bottom of the distributor.. Its leaking oil wear it meats the block..
The question I have is there a O-ring at the bottom of the disributor?
Guest
Posts: n/a
Yes, there should be an O-ring at the bottom of the distributor. The O-ring shouldn't be more than $1 at any auto parts store, but you may want to have someone replace it for you because you REALLY need to know what you're doing to pull the distributor. It is VERY easy to screw the timing up.
