PDA
View Full Version : launching a turbo car
fl_hmong_racer
09-23-2003, 11:00 AM
well i was just wondering wat the best is the best way of launching a turbo car.
qitstrn
09-23-2003, 11:14 AM
Well give it some gas and slowly release the clutch.If you dont have a clutch then just stab it!
T3T4240
09-23-2003, 11:27 AM
slip slip slip slip it, then gas gas gas gas it......
quickcivic
09-23-2003, 11:32 AM
Get a electronic boost controller and slip the clutch a bit on your launch..
fl_hmong_racer
09-23-2003, 12:13 PM
thanx, so no need to tap on the gas to get the boost up?
T3T4240
09-23-2003, 01:15 PM
got 2 give some fuel then slip that beast then yoru good to go stumping away :)
flubyux2
09-23-2003, 05:34 PM
it depends on your drive train lay out.
if you spool your turbo at the line, you just make more power and put more torque to your wheels... unless you have Slicks or AWD, chances are, you cant handle a spooled turbo right off the line.
but, lets say you DO have a well-hooking setup (Either AWD or RWD or what ever)... if you sit at the line, just pump the gas, rev it up to redline and let the RPM's fall... rev the engine up and down... not a little, i mean PUMP the gas, youll hear your turbo spool every time you pump the gas, and your BOV will release every time you let off. when the last Yellow lights, get ready to slip the clutch. as you slip the clutch, feed in the throttle so you dont bog... but your turbo will be spooled and ready to hit full boost as soon as the clutch is released...
thats how you get 1.7 60' times on street tires baby... :deal:
Legato
09-23-2003, 06:30 PM
how would i get 1.5s or better
Vito_Corleone
09-23-2003, 07:23 PM
You would suck god's dick.
PoppaSmurf
09-23-2003, 08:04 PM
700+ whp and slicks on all 4 (john shephard proved that it works 8) )
Legato
09-23-2003, 09:16 PM
nice
bucci was saying somthing about the stock drivetrain saw 1.2s
qitstrn
09-23-2003, 09:57 PM
nice
bucci was saying somthing about the stock drivetrain saw 1.2s in his dreams:clown:
Solar Specialist
09-27-2003, 04:27 PM
I got 1.9s easy with shitty launches on some 225 nitto D/Rs. I had street pressure on them too, so that didn't help. I definitely recommend picking some up if you can.
Tom N
09-27-2003, 05:40 PM
nice
it was done with a factory awd tranny but the tranny was built.
John shepperd could do it but he wont launch his car that hard. Nor does he need to.
