Drag Racing Don't like turns? Tech talk about drag racing and drag event discussions here
Correct way to heat tires?
Old Sep 18, 2003 | 08:56 AM
MDIFYTD's Avatar
Uber lurker
Default Correct way to heat tires?
I've been to the track a couple of times but always with street tires. I'm thinking about buying a set of slicks but I don't want to embarrase myself or worse break anything. So I'm asking what is the correct way to heat your tires. Should you do it in the water box or just drive through the water and do it on the pavement in front. The reason I ask is because I saw both methods.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Sep 18, 2003 | 09:11 AM
flyinbrian's Avatar
I have always been a believer in backing into the waterbox, if possible. Then pulling forward a couple feet, until the rear tires are out of the water, setting the line-lock and putting the hammer down through second gear. Once I get the nod from whoever is helping me that day, I release the linelock and stand in the gas long enough to get away from any moisture on the ground and closer to the tree as quick as possible.
If you're bracket racing, the key is to keep your burnouts as close to the same as possible. Countdown in your head or your crew timing you and telling you when to go, 2 or 3 step rev limiter to keep the revs the same every time, etc., etc...
Lighting them up while in the waterbox is useless.
First off, on the initial spin of the tires, you sling water up into the wheelwells. This will drip all over your tires once done with the burnout.
Also, you have to get out of the puddle once you started...so you are driving through more water on your way to the line...bad idea
Everyone has their own way.
That's my .02
