PDA
View Full Version : mk2 supra swaps.....
Legato
09-16-2003, 03:49 PM
what swaps are there and turbo only swaps
and any sites with info....thanks
Kirk
09-16-2003, 05:17 PM
7MGTE from the MK3 Supra
My friend has one, real light.. 13 sec car with a stock motor.
- Kirk
Legato
09-16-2003, 09:10 PM
how much would this swap prob cost?
Kirk
09-17-2003, 07:22 AM
cheapest, you can find a tranny for 200-300, motor for 500-700
from there its a piece of cake
supratruck
09-19-2003, 11:40 PM
buy a 6m engine. and slap a 7m turbo setup on it....and you can run 13's cheaper and more simple. and dont have to replace the head gasket every day...
flubyux2
09-20-2003, 01:33 AM
you could get keep the 5MGE and drop in a 7MGTE crank and match the reciprocating assembly. Then put on the 7MGTE induction system (turbo) and tune it w/ an AFC on the Dyno... Theres a guy around the 'burg w/ this car. I think his name is Brian, hes got a white MK2, beat lookin, and has small "Race Related" stickers on the rear quarter windows.
MK2 w/ a 7MGTE swap is a very potent car. Despite the fact its a Solid rear end w/ 4 lug hubs... it can be made to perform... probably better than the MK3, mod for mod... considering that the MK3 is a turd. :roll: the only weak spot on that setup would then be the W58 tranny... just swap in the R154 and youll be good.
Legato
09-20-2003, 01:37 AM
arg i hate toyota engine codes....basically i have a transaction under way where i can get a mk2 supra in pay instead of money...it runs for a great daily while the laser is down but im wonderin if it has some real potentiual
flubyux2
09-20-2003, 01:39 AM
Well, to save you some time from reading my other post:
Yes, there is potential.
Legato
09-20-2003, 01:40 AM
i read it and got confused on some of it.... but thanks
riddlemr2
09-25-2003, 06:36 PM
If I remember from my supra days, the 7m-gte will drop in the mkII and will bolt right up to the auto tranny in the mkII provided the swapee and the engine are both autos. Then again, you'd force yourself into a boring way to transport yourself.
If the 7M-GTE will fit, won't then the 1JZ or 2JZ also fit? Of course it would be more expensive, and the wiring/computer stuff would get difficult. Would be preddy darn fast and a serious sleeper.
Legato
09-25-2003, 07:29 PM
the car is a 5spd and will stay a 5spd
Kirk
09-25-2003, 07:58 PM
The 7MGTE will fit..... My friend has an MK2 with a 7MGTE with an upgraded CT.. when the motor was stock the car was getting 13's all day long at the track
Legato
09-25-2003, 08:20 PM
sweatness i cant wait....but ill get the dsm running first
Kirk
09-25-2003, 08:47 PM
http://www.norbie.net/Project2JZ/
2JZ in MK2.. not like any of you will do this.. but still worth a look
hachibill
09-25-2003, 09:00 PM
flubyux2 the mk2 supras had independent rear suspension. it wasn't a dubble wishbone like the mk3. it had a semi-trailing arm rear set up just like my brothers 85 celica GT-S. the 2 cars were indentical from the front doors back. So if you see a 82-85 celica GT-S or supra it has independent rear suspension.
TurboJZA70
09-25-2003, 10:36 PM
sounds like you are talking about eric. his car is a jdm 6m with 7m turbo stuff on it and a Safc for tuning.
agentAndy
09-26-2003, 02:47 AM
if you need i have a 7mgte R154 trans i will LET GO for 200. works good and is in great shape. also has the slave cylinder
Legato
09-26-2003, 05:35 AM
is the r15 a 5spd tranny? and why are u getting rid of it?
TurboJZA70
09-26-2003, 05:37 AM
i would be intrested in this trans.
agentAndy
09-27-2003, 01:36 AM
yes a five speed.
i dont need it. i got a newer one with my clip. was going to heep it(minus the bellhousing) for a spare but dont have room. i can meet halfway to tampa if someone wants it.
agentAndy
09-27-2003, 01:37 AM
only a 30 min drive.
Legato
09-27-2003, 01:43 AM
na or turbo.... miles etc...
Kirk
09-27-2003, 09:15 AM
R154 is the turbo 5speed
Legato
09-27-2003, 12:58 PM
ok so 200 is a great price then?
Kirk
09-27-2003, 01:03 PM
yea make sure it shifts nicely and check the mileage
don't wanna get stuck with a chewed up transmission
I think my friend might have a couple for sale if you want me to give him a ring.
Legato
09-29-2003, 02:46 AM
ol right
what was the dudes name with the 7m in his mk2? like chris or somthing....he does run his mouth alot but he knows his mk2s...u know his name or how to get ahold of him? i dont work with him anymore
any other info for the mk2 let me kno
PoppaSmurf
10-11-2003, 11:12 AM
so....what exactly is involved with this, wiring harness/ecu, motor, clutch/tranny, and be done w/ it...can a Mk3 rear end be swapped in, i know the MK2's dont have the strongest of rear ends..
JapDanny
10-11-2003, 07:03 PM
It will basically drop right in . You can either bolt the 7m manifold on the 5M and boost it till it blows after you notch the manifold . Or just drop teh entire 7M-T motor in and wire it up nicly with a R154 . The MK2 Supra's rear is strong enough .
joeyk
10-13-2003, 11:45 PM
what is strong enuf?????
If it is as strong as the mk3 rear end then no I have went threw 3 rear ends in my supra and the one i got now has to come out so ..
hachibill
10-14-2003, 08:29 AM
Toyota motors rock but their rear ends and tranny's arn't the strongest. I've busted 2 rear ends and atleast 4 trannys. I know the r154 is stronger than a w58 but you will spend less if you build a w58 for ultimate strength. so if your going stock use the r154 but if your rebuilding go with the w58(cheaper and more abundant)
PoppaSmurf
10-14-2003, 12:59 PM
what about the TruTrak LSD's out of the 4X4's? :D, those are supposed to be pretty strong, one of those with a nice clutch/flywheel setup matched up to an R-154 should make for a damn nice driveline setup...time to cryo some axles?? ;)
flubyux2
10-14-2003, 07:57 PM
you need a 1G-GTE... thatd be icy AND hott at the same time!!!
the MK3 likes the break panhard bars or something... some kinda bar breaks if you get a REAL good launch...i forget what it is...
anyways... a 7MGTE is more than enough for an MK2. 400 RWHP on a CT26-based turbo is within reach. imagine what 400 RWHP can do for you in a MK2 ;)
PoppaSmurf
10-14-2003, 11:42 PM
it'll probably be like that, 7m w/ 60-1 CT26 10* clip, set up for external gate, lexus/550's, s-afc, fmic, and some meatier tires in the back :D
flubyux2
10-15-2003, 12:08 AM
CT26/60trim, no clip... supporting fuel and air mods... 400 RWHP w/ good tuning on pump gas... nizzle!
wanna see the video again? :D
williamb82
10-17-2003, 03:15 AM
well, the dude with the 7mgte mkii that runs his mouth alot would be me. my name is william. the guy with the white beat looking mkii with the 6mgte is eric, i helped him turbo the car. i currently am looking for a red 84-86 mkii to replace my 84. some idiot ran a redlight awhile back and totalled it. it ran 13's on the stock motor@8psi with 3in exhaust and an hks smf intake with 3 cylinders low on compression. i rebuilt the engine about a week before the car got totalled so have a new7mgte waiting for a body. it ran harder at 5psi after the rebuild then it had previously at 12psi. i broke 2 diffs at sunshine after i lifted the rear suspension a bit, never made a full pass so dont have a slip. and the 1/4 mile passes were at bmp at 1 of the 1320 events before the suspension mod. all the mkiv guys told me i was running 7.7 in the 1/8th. my clutch was slipping really bad(never get a kevlar disc) so the 1/4's were in the high 13sec range. as soon as i shifted to third you could smell the clutch. anyway, if you have questions on the swap email me and ill tell you what you need to know.
william
williamb82@yahoo.com
williamb82
10-17-2003, 03:18 AM
oh yeah, and i bought a trutrac lsd to solve the diff problem, when i get another mkii i will have everything ready to test out to see if it will hold up. it should since with the gearing on most 4x4 rock crawlers you can see up to 1600lbs/ft at the wheels, and the lsd was designed for the front diff of a toy 4x4.
william
creepy1ne
10-17-2003, 04:43 AM
i went to ITT when eric was first getting his 6m setup for the white markII.
Slash
10-17-2003, 02:12 PM
that white MK2 autox's all the time right? i think i saw him running at GIR last weekend with i guess it was the 6m i dont know enough about the motors to identify by looking, but he said it was ajapnesse motor...
williamb82
10-17-2003, 02:59 PM
yeah, he autocrosses alot. ocasionally i go out there as well but dont have a car to run since my 84 is totalled so just watch. id be either in a silverish blue 85 or a maroon 86.5 n/a
william
