View Full Version : Need specs on this amp
50u|\|d57|234m C0|\|71|\|1um. 17'5 4 6 ch4|\||\|3l b|21gh7 ch|20m3 f4c3d 4mp. L1m173d p|20duc710|\|. 1 534|2ch3d 50u|\|d57|234m5 5173 4|\|d d1d |\|07 f1|\|d 4|\|y 1|\|f0 0|\| 17, 4|\|d 4|\| 3m41l 70 7h3 c0mp4|\|y 15 y37 u|\||237u|2|\|3d. 1f 4|\|y0|\|3 k|\|0\^/5 1'd 4pp|23c1473 17.
heres what i found
Ok, anyway, the amp is a soundstream continuum. This was a quite limited production to celebrate soundstreams anniversary (forgot which one ..25th?). I think there were only 5-10 sent to my state. Anyway, it basically has everything you would ever need for an incredible system.
POWER: 75 X 4, and 300 X 1. Of course, that is VERY conservative because soundstream doesn't use voltage regulation, and these numbers are for 12V, and most cars run at more like 14V. Anyway, those numbers are RMS values, NOT PEAK. Those numbers are also for a 4ohm load. This amp is capable of a 1/infinity load impedance. I'm pretty sure thats what the manual says even. Basically as many speakers are you can stick in parallel, this amp won't quit on you.
CROSSOVER: This amp has the best active cross-over built in that I've ever used. complete control, 3-way, 18db/octave. This isn't your average lowpass and highpass, you have alot more control than usual, and the ability to do bandpass.
FINISH: The heat sink is polished aluminum. Looks great.. There are only a few polished soundstream amps, and they are all special editions or expensive as hell.
Originally posted by rangcrx
wow a four channel that can bridged mono wow thats new to me
its a 5 channel amp, 4 channels for fronts/rears, and 1 for subs, lots of companies do this.
and what? yorue getting rid of the MTX?
rangcrx
09-01-2003, 03:51 AM
not sure mite be keeping it but i need more to power those that amp will not do it unless i bridge it but but still thats not much power even from Mtx im thinking on going with the new KICKER SX1250.1 you ever heard one
nope, sure havent, maybe the arc audio 4000XXK is more your liking
4\^/350m3, ju57 7h3 1|\|f0 1 \^/45 l00k1|\|g f0|2. 7h4|\|k5 4 l07 J3553
Originally posted by Vapor
awesome, just the info i was looking for. Thanks a lot Jesse
youre welcome, its what I'm here for ;)
Content Relevant URLs by
vBSEO 3.2.0 RC5
