PDA
View Full Version : just got my 1jz
agentAndy
08-08-2003, 04:05 AM
whats up to all the toyota fans.
just got the 1jzgte in the shop. failed to post on tamparacing yet, so we will be the new kid for a while. We are located in sarasota florida. real close to tampa. (use to be there) As soon the JZA70 is done we will bring it up for some meets and events hopefully(soon as we get settled in)
And again, thanks for the time.
Andrew Carroll
pics (http://www.tamparacing.com/forums/showthread.php?s=&threadid=107460)
93supra
08-08-2003, 02:48 PM
Sounds good.I would love to see how it turns out keep us posted maybe some pic's.Good luck:-)
Muddy
08-08-2003, 04:57 PM
I would like to see it when it's done. :cool:
agentAndy
08-08-2003, 06:24 PM
sure thing guys i will try to post pics as soon as possably. really busy with the full swap right now.:cool:
Kirk
08-08-2003, 06:42 PM
sweet deal, put up pictures of your car
I am going to be buying another MK3 to do a clean 1JZ swap on pretty soon after I am over w/ my current supra
agentAndy
08-08-2003, 10:47 PM
i might sell it someday:roll:
oh I NEED JZA70 MOTOR MOUNT(right side) asap!!!!!!!
ASCARROLL@COMCAST.net:mad:
J-Dizzle
08-08-2003, 11:18 PM
bro sounds nice , i had the same plans before but cant afford it right now , i want to do the same thing some time in the near future, try to post pics of this swap i would love to see it.....jason
agentAndy
08-09-2003, 01:06 AM
jason, i will try to get some pics up REAL soon so i can share with all the 1j. today we had a set back from a broken motor-mount, so we will be searching feverishly to find one. if you or any of your contacts can obtain this part real soon we will gladly give some cash to the finder. the toyota part number is 1236142050. Jason, if you plan to do the swap we can provide a clip and install for a good price(quality work is worth it). the full install is the 1jz, custom harness extention, trans, ecu, fuel pump, TORSEN REAR SUB ASSEMBELY(gear type LSD), and crossmember(if needed). Radiator and intercooler is also included. some clips come with some bolt-ons. Last clip had greddy airnex, and blitz BOV. please give some lead time for this to happen(clip must be attained). your car would be the last thing involved in the swap, so you can drive for as long as you can until the full swap. let us know and good luck and safe tuning:D
P.S. Dont forget we need that mount.(90-92 jza70 supra motor-mount for the right side)
Andrew Carroll
agentAndy
08-09-2003, 01:10 AM
Oh, JASON
if you want the 89 and up (turbo)spoiler and front bumper(with fog lights, turn signals, grills, upper cover) i will trade you that for the same on your car. get us your paint color number from the ID tag in the door jam and i can paint it to match if that makes the deal. Please let me know
flubyux2
08-09-2003, 09:46 AM
Agent8... you just need the round style motor mount. you could even find one in an 89. there are square mounts in the 89's also. but anywho, talk to Magic Auto, their # is 727-573-7751. i know for a fact that the car they have there is a 90+. its the same color as mine, only its NT. you can get that Mount from them.
BTW, dont forget the 2JZ/Land cruiser throttle cable.
Oh, and what are you doing about the Hydraulic cooling fan? Keeping it or tossing it? You know, you can use ford Contour/cougar electric fans from 96+ cars. they are a perfect fit for the MK3 radiator. you can get them for pretty cheap, and when properly installed, they move MASSIVE amounts of air. infact, you MUST wire it to a thermo-switch otherwise itll overcool the car and itll stay in openloop-warmup mode forever.
Oh, and if you want it to have AC, be sure to keep the AC line block from the original compressor and bolt it to the 1JZ compressor. i personally would go for AC... its florida :D
btw, where are you getting the clips from? are you a middle man or are they coming straight from the East? most of my friends recommend Jarcoinc.com as they have soem high quality standards. How much are the clips costing now?
oh, and how are you working around the engine harness? who is doing the wiring for you? I know Mike Urbano was modifying the harnesses. you just ahve to send your 7M and 1J harness and he will splice/lengthen it and send ti back... for about $600.
BTW, Kirk... i thought you were Anti-MK3 cuz they are old and tried... and out dated and achaic... waht gives?
Kirk
08-09-2003, 10:31 AM
this is what gives
flubyux2
08-09-2003, 10:42 AM
not bad, but Maxx Evo front end is not my flava... Evo frnot end needs to stay on Evo's :D
looks liek a black version of Trey's car... but w/ homie-chromie rims...needs some ADvans or Ray's wheels.
anyhow, you should quit changing yoru mind... next thing you know, youre gnona be talkin about a Mister two or a taco or something.... Jeez... crazy kids, cant make u their mind :D but, either way, i wanna get in on it so i can figure out what to do.
why dont you get that supra tahts for sale, for $1000? its an automatic, but you can convert it to stick w/ the front cut parts cant you? im not sure if the RHD pedals will work in a LHD car...
Kirk
08-09-2003, 10:51 AM
no thanks...... my next supra will be a 91/92 black or red/black
I am done buying cheapo MK3's......
and btw check out my website, in the forums there you should find some good info on the swap.
- http://www.supramania.com
flubyux2
08-09-2003, 11:24 AM
get a 93... if you dont wanna cheapo car.
Kirk
08-09-2003, 11:29 AM
there are no 93 mk3's...
i meant cheapo as in run down piece of shit high mileage $1000 supras.
I'd like to own a black preferably, so it matches with my MKIV. The MKIV wont be done until sometime early next year (as in turbo kit, body, etc.)
flubyux2
08-09-2003, 11:38 AM
right, so if there are no 93 MK3's, that would make it PRICELESS right... the opposite of cheapo. :D
Kirk, im gettin the feeling that you are in a pissy mood or havnig a bad day... whats the dilly
Kirk
08-09-2003, 11:45 AM
I'm fine, just want my car back - sorry.
It's been at the shop for almost a week and a half now....... and you know how it is when you don't have your car.
flubyux2
08-09-2003, 12:14 PM
its cool, i feel your frustration... it sucked to be doing a HG swap, seemingly forever. i bought the car in January and have only been driving it for about a month...
it always takes twice as long to do something than you originally plan for... but at least you know they arent rushing/skimping on the job.
agentAndy
08-09-2003, 04:58 PM
yea, i have done my harness myself. Mike urbano does not do quality work. nor is is customer rating very good either. i already got some aftermarket mounts. yea i know the 89.5 mounts work but the local dealer didnt have them and they always break. www.turboboss.com has the mounts i got.http://www.turboboss.com/cat.pl?make=Toyota&model=1JZ%20Supra&cat=Suspension
every thimg else is ready for the motor. in the future i will do some harness extentions if anyone needs. PEACE
flubyux2
08-09-2003, 06:29 PM
Thats great news.. i know Kirk will need one, i might go w/ a 1J swap eventually too.
I always was under the impression that mike's stuff was ok... but hey, if you heard otherwise and have a better solution, that is awesome. you gota keep us updated!!!
btw, i thought it was the Square motor mounts that are the ones that like to break...
but anyways... is there anything thats holding up your process now?
oh, and you are gonna take pics right?? :naughty:
agentAndy
08-09-2003, 08:06 PM
yes i will share pics with everyone as soon as i get them uploaded to my home pc. the only thing i am waiting for it to get the new poly/cnc aluminium mounts. they should be here tue/wed hopefully.concerning mike urbano; i was informed that more than a few of his customers had recived bad harness that lacked electral continuity on some wires. this could leave someone looking for ever to find the problem. the main point is to get the under dash plugs re-pined and sorted out. sorry if i take a few to get the pics.
TurboJZA70
08-10-2003, 05:34 AM
Who did you get the motor from?
agentAndy
08-10-2003, 05:49 AM
jarco . it came with aftermarket intake, bov, and turbo timer.
the torsen 4.10 come with also.
agentAndy
08-10-2003, 03:48 PM
might be able to get a deal on the clip if you go through us because this will have been our third order fron them(because of quality and service), so it might happen. with Robert and myself trying to get a shop going this will help our credibility,and experience.
flubyux2
08-10-2003, 03:53 PM
jarcoinc.com rules, thats where everyone has been recommending placing orders... they keep getting new shipments in, but its like first come-first serve and the 1jZ cuts w/ the 5speed aer VERY VERY high demand... but they have had an Auto tranny clip in their inventory FOR-EV-VER. their prices are al ittle on the high side, but i keep hearing how they have good quality, so i would DEFINITLY pay a little more for more piece of mind.
btw, whats your shop address? i like to come out and take a look at your operation... maybe bring my Digicam and take some pics... for posterity.
J-Dizzle
08-10-2003, 10:39 PM
shit , well my car is for sale and it has a spun bearing ... im in the process of selling and possibly buying another one...how much for this swap man? if i would to do my car how much ?cause i hav an automatic............jason
J-Dizzle
08-10-2003, 10:40 PM
oh about this 89 stuff let me get tomorrow after school and shit and we can work something out
agentAndy
08-11-2003, 06:13 PM
for SURE! we are running out of the garage but SOON will will relocate to a wharehouse in the neiborhood. the place is in sarasota. not to much to show but hell whatever. if you want we can meet up and i will show you the supra.
agentAndy
08-11-2003, 06:22 PM
oh and jason. for a DEAL we could do it for 1000-1500. remeber this will include the harness. Arnout-vander-kamp wants 600 just for the harness! this would be the full swap of the jz and the rearend. look to see if the eigth digit in your body vin number id a "K". count backwards from the last number in the code. if it is a "K" we would not need to swap the cross member(full day) it would take about two to three weeks to ensure that it is done right. maybe faster. you will need to buy some parts for the swap though. i would also recomend changing the cluth and timing belt wile the motor is out. a full poly bushing kit would be good also wile the subframes are out. lets talk.
agentAndy
08-12-2003, 05:16 AM
really, i work a full time job, but i will get time off fo REAL work. i can do it for you if you really want it.
agentAndy
08-12-2003, 05:17 AM
if you try to sell with no avail maybe we can work a deal(i want your supra)
J-Dizzle
08-12-2003, 03:36 PM
well i hav 3 people interested right now, i would like to get 1700 for it , lowest 1600.......let me know, OH and im buying an 89 thats in good ass condition and would consider the swap but it wouldnt be for about 4-5 months and that shit....
http://www.tamparacing.com/forums/showthread.php?s=&threadid=101182
agentAndy
08-12-2003, 04:21 PM
thats good. try to get a 89.5 and up. makes the swap a little easier. a 91 or 92 is ideal but the 89 will work as well. when ever you want to do it we will. oh what exhaust do you have on the one in the pic?
J-Dizzle
08-12-2003, 06:30 PM
its 2.5 in piping from the end of the stock downpipe to an Arospeed Muffler, for some reason evry pic i hav of it , it looks different , its eiehter dull looking or shininy polished looking:D
agentAndy
08-13-2003, 05:42 AM
thought is was hks dragger from that view. never seen one.
if you dont sell right away do you want to swap front ends?
J-Dizzle
08-13-2003, 03:29 PM
yea lets go for it , might help the sale go faster to thses bitches that hav to get their $$
agentAndy
08-13-2003, 04:47 PM
hks dragger it is.
J-Dizzle
08-13-2003, 05:09 PM
what the hell r u talking about?
about these parts u wanna swap , when would u like to do this ?ill check my schedule tonight to see if i work this weekend.. do u know anyone who would LIKE TO BUY MY CAR , cause i need to get rid of it immediately, it just sits in the driveway and i need to vbuy this 89 im looking at , let me know, jason
agentAndy
08-13-2003, 06:22 PM
does it run? i want to swap out the front bumper, turn signals, fog lights and top part so i can convert my car to the old style. i have the newer style.the spoiler too. i will pay for the painting of the parts you get if you want.
agentAndy
08-13-2003, 06:24 PM
oh yea it has a spun bearing. i will see if anyone wants to buy it. if i was not doing the swap i would take that baby off your hands
J-Dizzle
08-13-2003, 11:27 PM
iight , i dont hav the top part thing , mine waz rotten so i took it off but ill buy that top piece from ya,, yea i hav everything , the front bumper has a smal section wher the paint is chipped but its small,and the right turn signal is slightly cracked, everything else is fine, How bad is the paint on yurs? and do u hav a Hood , black or marroon , i dont care i need to put a dent less one on cause i hav some hail damage on mine.......give me a call around 2-230pm, 813-996-1726 ask for Jason so we can set this up some time
agentAndy
08-14-2003, 04:08 AM
for sure. i will drive up there if needed(if you remove it now keep all the nuts and bolts and supports, we will trade those too so it is a good fit)
mine is red.
i will call you.
TurboJZA70
08-14-2003, 12:04 PM
i have an 88 supra that you can do body panel swap with if you have a 90-92 panels any time any day.
agentAndy
08-14-2003, 02:47 PM
yes it needs to be a full swap. email me with details ASCARROLL@COMCAST.net:)
agentAndy
08-14-2003, 02:50 PM
jza70, i PM in your box about it.
Mr 2
08-14-2003, 04:14 PM
agent89 why can't you type everything you need to type in one post. I am going to start deleting your second posts.
Slash
08-14-2003, 04:56 PM
Hes got the ADD madness like me...... I do that on aim but i dont do it here.. My friends get hit by like 50000 million posts and their brain shorts out..... when in reality i coulda just said.
Yeah just meet me at wendys in 5 minutes. Bring the money and your buying....
agentAndy
08-14-2003, 11:04 PM
yes
agentAndy
08-14-2003, 11:06 PM
i have add. sorry guys. i proof read the post after i post it than remeber stuff i ment to say. should learn to use the EDIT button.
i will try to stop that. in the meantime sorry.
J-Dizzle
09-10-2003, 12:25 AM
hey Andy post yur pics of the 1JZ in the car if its in yet??? i would really like to see, jason
agentAndy
09-10-2003, 04:14 AM
right here 1jz swap pics (http://www.tamparacing.com/forums/showthread.php?s=&threadid=107460)
Slash
09-11-2003, 02:36 AM
thats mad hot.... i wana ride
agentAndy
09-11-2003, 02:42 AM
soon as it done you can(vomit bags not included):D
