View Full Version : sub problem... help !!!
yaheardbish
07-27-2003, 10:41 PM
subs was sounding just fine... listening to it at a moderate level while driving... all sudden i switched track and NO BASS! checked all wiring and everything seems in tacked and theres power and everything going to the amps. took a friends sub and hooked it up to my amps and still no sound. what could be wrong?? help please.
Miles
07-27-2003, 11:30 PM
is the amp actually turning on? check the fuse...
1. check if the amp is turning on like he said, do some circut testing
2. speaker wires
3. sub info, enclosure type, subs blown? take your subs hook them to friends amp too
yaheardbish
07-28-2003, 06:25 PM
amp turns on, checked and double checked all wires and its all in tacked, subs is a eclipse aluminum in a sealed box and are not blown. what else could it be guys???? im going crazy.
yaheardbish
07-28-2003, 07:31 PM
yep
StreetStangGurl
07-28-2003, 09:25 PM
ACK that sounds like when one of my channels went bad on my amp...get that checked out if it's not the wires in the box
So the sub itself will not play in a friends car?
Get a AA battery and touch the ends on the wires going to the speaker and see if the speaker makes a pop pop noise.. that will verify that it is plugged in fine and getting signal...... if anything your amp is FUBAR
yeah if your subs will play in your buddies car theyre fine if not there smoehitng there... just keep going thru eliminating shit
Content Relevant URLs by
vBSEO 3.2.0 RC5
