PDA
View Full Version : Nissan/Infiniti Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184
  1. KA24DE Head filling with oil
  2. Ka breakin up when wot?
  3. I need more front travel!
  4. blown head gasket: repair or engine swap
  5. Car intermittently losing power.
  6. S13 Sr20 Engine mounts
  7. Good Nissan general mechanic
  8. z32 knuckle question...
  9. Shift issue
  10. Vert top replacement suggestions??
  11. KA24DE Shims/buckets
  12. Issues after swap...
  13. This seems a bit high!?!
  14. My brakes are being a bitch.
  15. Wheel studs
  16. Valve stem seals (ka24de)
  17. 86 Hardbody z24 lost all power while driving
  18. who has a ka s13 w/ working heat?
  19. Does everyone have trunk rust? s13
  20. make this a sticky
  21. Dash swap question...
  22. 92 Infiniti G20 Question
  23. crazy chattering/ clicking noise
  24. Beams 3SG/6spd into S14?
  25. sr20det need help!!!!
  26. Scott/Enthalpy
  27. S14 5 lug front bearing/hub issue #5698
  28. in/out fuel lines on afpr
  29. Auto => Manual Swap Q's: 5-Spd drive shaft vs Auto drive shaft...
  30. Good site to buy a complete s13 front clip?
  31. KA24DE throwing code 12 help plz
  32. s14 engine harness
  33. Ka24De wont rev pass 2500rpm new to this please help need car bad
  34. Z32 bmc t/o
  35. ka24de Engine Harness ?
  36. stretching tire on a 17x10.5??
  37. stretching tire on a 17x10.5??
  38. which helicoil to use..
  39. Seat ????
  40. Rb26 crank question
  41. 2jz swap in s13 help
  42. DS support bearing
  43. question about IACV and AEM
  44. Bout them Ka rebuilds...
  45. super annoying squeak (s14/coilovers)
  46. Oil pressure issues
  47. ka injectors won't fire
  48. HELP...ka-t breaking up in mid boost...HELP
  49. alignment! !! any suggestions //?
  50. Subframe / Rear Suspension question....
  51. vq35 question
  52. Help s13 KA Need to run richer
  53. solution to excessive rear end sway? (s14)
  54. 04-06 maxima/ infinity 5 speed auto shift problems?
  55. Using a lifeline..JDM WIRING PROS I need your help!
  56. KA24DE timing issue
  57. where to get Hawk pads 'locally'?
  58. ka24de idle stall
  59. Code 21 1987 Nissan Pathfinder z24i
  60. KA24DE CAM swap options! some feedback on how each cam setup feels! FAQ!!!!
  61. Help plz
  62. rb25 ticking/knocking. think tank time
  63. sr20det help needed
  64. Couple of electrical questions---s13
  65. guys i need some help please. suspension questions
  66. 2002 Infiniti G20 Starter Replacement
  67. reman j30 axles?
  68. Dare i say WIRING ISSUE!
  69. Altima Ka24de Distibutor Question
  70. Front Struts; Why Does the Left Side Cost More Than The Right?
