- running ka without Iacv and other upper intake sensors
- 91 S13 running weird...
- 5 lug question
- TDO4 vs T25/28
- q45 s14 rear end swap
- problems w/ my s13
- S14 Left window not working now
- 03 350Z Help Needed. Electrical.
- Intalled new brake pads and rotors, having uneven wear from pads and smoking
- Wiper mist function?
- afc help maf signal wire
- Car wont start....please help
- what size bolts go into the T25 outlet elbow to hotpipe
- Idle issue s13 dual cam.
- sohc timing question
- Another KA question before I build soon.
- lets talk about pinion and ring swaps
- who can do 5speed swaps on 96 240
- ka24e vacuum removal help
- fuel pump wires smoking. need help asap
- wanted to get some more opnions on my SR20det knocking noise
- alternator bottom bolt wont come off?
- S13 Confusion
- Turbo Oil & water lines for Sr20det ?
- clutch fan wont disengage
- Anyone familiar with the dreaded sr swap no spark or fuel condition?
- basic power/reliability upgrades for KA24E
- SR20 breaking up and losing #1 cylinder
- Sabotage? Or, something came apart?
- How to turbo a stock ka?
- Need help identifying wires
- Brake line clips on the fire wall
- Best Clutch For RB25?
- Boost levels and Tune ???'s
- need someone better at diagnostics to read this real quick.
- s13 problem. Need Help.
- Instrument Cluster Problems.
- Temp gauge question
- Is it me???
- need help: tail lamp 15fuse keeps popping/blowing, has never done it before.
- new car new problems
- where to find s13 sunroof weather striping
- s14 Base to se upgrades???
- how much hp should this rb20 have im thinking of buying
- 89 240sx wont start!
- 300zx fuel pump - need help
- Anybody know what wheels these are?
- white bunny clutch
- ka24EEEEE help
- VSS for Nissans specifially 300ZX Z32
- sr20 no spark please help
- ka24de cylinder / piston disassembly help
- need help...
- s13 bogging out, falling idle, "limp" mode...help
- S13 5lug question
- will it work
- sohc to dohc CONSULT wiring question
- Ka batery problems....
- Fitting size
- Dear Nissan Forums
- i have a 1995 nissan 240 making a funny sound from the head help...........
- Where can i buy good chassie,top harness and ecu
- bad diff?
- RB25DET misfire under boost!! causes?
- SR20 alternator issues
- Benefits of using s14 subfraim in s13?
- Turbo choice..
- Nissan shops in St. Pete/Tampa?
- Forged Performance: First G37 Coupe Greddy TT
