PDA
View Full Version : Nissan/Infiniti Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184
  1. rb25det s1 on z32 ecu...
  2. Oil catch can question
  3. wtf bougt a t25 wastgate wont bolt up?
  4. S14 a/c lines
  5. exhaust burn hole in carpet...s14 need exhaust shield or 5x5inch weld
  6. Where to go for R32 GTR front lower control arm
  7. s13 rear suspension question
  8. Silvia RHD conversion question.
  9. Interior wiring diagrams
  10. car issue ... extremely lost :(
  11. Car shoots up to 5k rpm instantly
  12. A/C questions
  13. JGS manifold/wastegate inquiry
  14. nissan 240 help
  15. KA-T or SR20?
  16. S13 ka24e alternator bracket and ka24de alternator bracket
  17. Ignition issue...
  18. Engine break-in
  19. SR20det idle problem. Please help!!!!!!!!!!
  20. 96sx se 1.6 to sr20ve
  21. Please help (many issues with my 1990 240sx sr20 red top)please help look
  22. Sr20det crazy issues?????
  23. car has a problem, of course it does, it's a 240..
  24. R33 clutch master into S14
  25. diagnosing A/C trouble
  26. Ka running rich and dying out randomly!
  27. energy suspension bushing kit?
  28. 240sx to r32 questions
  29. 20x 1/8 mile runs at sunshine tonight. Looking for helpfull input.
  30. Passenger side camber
  31. SR20 cam selesction.
  32. body wiring difference.
  33. opinions on up to date fia rated seat
  34. A/C shop Tampa??
  35. dash and taillights not working :/
  36. KA trans sticking, hard time going into gears?
  37. In stock clutches ... Who has em ?
  38. s13 sr20det hot with a/c on or highway cruising
  39. Ok, Rb guys got a question for you.
  40. s13 sr gasket help
  41. Help! (Redirect)
  42. KA24DE Stumbles after start ??
  43. RB25 fuel pump help?????
  44. who can chip nissan ecu's?
  45. Looking to cage my s13 vert / REP YOUR CAGE BUILDER
  46. OEM electric fan not working
  47. SR20 backfire and/or back pressure pop
  48. slave cyl question
  49. sr build question
  50. anyone have a 93 or 94 hardbody 2wd automatic?
  51. Battery keeps dieing ???
  52. Engine overheat when off???
  53. "New" 255plr Walbro Fuel Pump - Popping fuses??
  54. s13 speedo question
  55. something bent?
  56. harness covering?
  57. Opinions on clutch disc with stock pressure plate
  58. To my fellow Z guys i have a delima and need you advice
  59. rb25det bogging down...
  60. rb25det running hot!!
  61. Where can I get a new radiator for my 240?
  62. 93 hardbody v6 5 speed conversion
  63. sr20det timing chain guide questions...
  64. j30 5 lug conversion for s13?
  65. 93 hardbody auto - erratic shifting
  66. z32 clutch pedal in s14, anyone actually done this?
  67. No spark from coil...help
  68. Power steering lines
  69. Megasquirt Help !
  70. rb25det vtc questions
