PDA
View Full Version : Nissan/Infiniti Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184
  1. SR turbo oil feed leak - best fix?
  2. Convert your S chassis to Double A Arm rear suspension!
  3. Turbo my 300z
  4. other neat cars besides s13s and s14s to put sr's into
  5. are the z31 turbo wiring harness's the same as the n/a
  6. Z32 5 spd swap
  7. Big Nissan Turbo Power......
  8. Spec V Dynp
  9. does anyone know were I can get a z31 turbo ecu and wireing harness?
  10. MB Battles not discontinued.
  11. You know you own a s13 when
  12. how easy is the 2jzgte to work with? compared to a KA24DET
  13. what wing is this?
  14. Wheel/tire question
  15. Need help: Engine problem/ maybe Fuel/spark/ecu issue
  16. battery light on after sr swap
  17. OBD1 codes
  18. .../sigh
  19. so a new VG is in order
  20. I need a favor
  21. help I have a problem!
  22. blinker problems.....
  23. perform this experiment for me if you have an SR.
  24. HELP!!! timing, idle, and smoke!!!!
  25. what mods would I have to do to put a RB20DET in my z31????
  26. LT1 Swap/ info
  27. SR wiring gurus help me play beerpong!
  28. what good this website is!
  29. can someone reply my message?
  30. could I put a 89 z31 front end on my 86?
  31. Nissan!!!
  32. Isis
  33. Help No tail lights and no dash lights
  34. s13 door panel removal
  35. read this
  36. ka-t weird idle vacuum reading... Help plz.
  37. anybody got weekendwarrior's phone number?
  38. tire rim offset fitment size calculator
  39. 5 speed swap question!!!
  40. nissan 350z convertible hardtop
  41. Q45 Brakes
  42. Problem!! Need Help!!
  43. spark plug question
  44. Advice Needed With Bolt-On's
  45. Help Please
  46. SR throttle problems..help?
  47. turbo 240sx help please
  48. Wastegate Springs?
  49. vlsd question ?
  50. weird noise question.....
  51. yall are sleepin on the illest thread...its down below "vk56"
  52. 180sx ABS diff != 240sx ABS diff?
  53. You all will LOLz
  54. z32 swap engine opinions?
  55. Anyone have carfax?
  56. can somebody plz?
  57. WTF??? balancing my ca18det. ?'s
  58. headgasket question
  59. KA>SR Tranny conversion write up!!
  60. this is pissing me off/fuel pump issues
  61. 2006 sentra SE
  62. Any hubs to decrease track width ?
  63. KA24de build
  64. are sohc and dohc ac compressors and power steering pumps the same?
  65. WTF is going on here- tach preoblems
  66. whos good at pullin/rollin FRONT fenders??
  67. here's what the mechanic said
  68. Drifting - gateway to terrorism and homosexuality.
  69. SR20DET tubular manifold. or not?
  70. tryin to find my old 240 sold it for CHEAP and its in orlando
