PDA
View Full Version : Nissan/Infiniti Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184
  1. s13 Fender
  2. s13 brake locking?
  3. Headlight problem **s13**
  4. S14 Zenki Question...
  5. SR20/S14 A/C questions...
  6. 350z G35
  7. Sr20det
  8. What Nissan Turbo do I have?
  9. Weird fuel problem
  10. Knock sensor bypass??
  11. 350z startup issue, help!
  12. 02-06 nissan sentra se-r spec v parts wheels LOOK
  13. need an opinion
  14. starting problem
  15. LMAO headgasket
  16. looking for advice in which
  17. need help...
  18. S14 Issues Once Again!!!
  19. RB20 Question... Oil cooler?
  20. SR20DET Blacktop w/ Garrett GT2871r .64 turbo dyno charts
  21. SR lagging at WOT...?
  22. tires rubbin
  23. injector question
  24. Need someone with a sohc KA
  25. wierd spark issue
  26. need some help pulling motor
  27. steering wheel puller
  28. ECU power when wire jumped in relay, but only when ignition is off? DOHC Swap.
  29. stupid z32 brake question.
  30. sr20det freeze plugs
  31. buying an S13 tomorrow... HELP!
  32. Aftermarket gauges suggestions?
  33. any nistune dealers in tampa
  34. Actual tech kind of: Rod torque ?
  35. Altima cranks "funny", wont start (VIDEO)
  36. S14 Seats
  37. need someone who knows RB's!!!!
  38. Need help with cluster.
  39. Sohc trans on dual cam ka?
  40. S14 window help
  41. 240 intake manifold on a D21 pickup!! Help!!
  42. Identify the following:
  43. fenders rolled ???
  44. shift knob recommendations?
  45. Identify 17" MOMO rims & fit S13 z32 brakes
  46. Need Tech Help Now! Please Now!
  47. What do you do to maintain your car after events?
  48. Painting car soon. Need paint code.
  49. weird issue help
  50. brake question
  51. Whats a jdm kouki bumper worth?
  52. s13- Electrical prob- speedo/RPM/Temp/ Seat Belts
  53. 300zx z32 n/a to turbo
  54. Little tricks you have learned on the way (CAR RELATED)
  55. How can you make soch cluster work with DOCH wiring harness
  56. Will Rota Downshift fit on Z32 brakes with 350Z rotors?
  57. 1985 300zx
  58. still bogging at idle...
  59. Great company
  60. Nissan Tech Info. LOOK HERE FIRST! ca, sr, ka, rb, vq, vg, etc.
  61. 4-lug to 5-lug and wheels
  62. will s13 front control arm work on s14?
  63. need help guys
  64. A/C problem(DOHC KA)
  65. tps problems(cant get right one)
  66. Violent Vibration at around 50mph+
  67. looking to switch to a hicas shell... info needed.
  68. Loud "clunk" after releasing the brakes
  69. Finally a solution to the Quest Alt
  70. so wheel spacers?
