PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333
  1. what it's going to look like
  2. spits and sputers
  3. smoking ac belt
  4. nrg ground wire kit?????
  5. injector flow test????????
  6. Type r swap into a 93 del sol
  7. Timing Belt
  8. B18a1
  9. crx wit jdmb16 question
  10. ITR Piston HELP!!!!!
  11. What Size Injectors
  12. motor oil
  13. Is 70mm T/B Too big?
  14. My newest mod... *pics*
  15. wat size fuel injectors?
  16. no power to my starter the small wire
  17. B18A1 bogs at 3k
  18. What are Rare?
  19. 91 accord erratic idle
  20. i need my turbo rebuilt.
  21. crx dumping fuel in cylinder
  22. 2006 Florida CRX/Civic Meet
  23. block code
  24. clutch/tranny f-d up??
  25. CRX + B16 + Which header?
  26. ITR Muffler?
  27. ITR Rod question
  28. ls swap
  29. shifter bushings
  30. quick ?
  31. Help
  32. Need help civic not running right!
  33. about rota slip center caps
  34. Info About Brakes
  35. compatability for rear lower tie bar
  36. a/c help
  37. Trying to locate a problem..
  38. What clutch is better?
  39. 2.3 Liter RDX engine into TSX??
  40. ek sideskirts on a eg coupe?
  41. Integra clutch problem?
  42. 450 cc injector...what does that mean?
  43. Any one know where i can find....
  44. Where can i get these RIMS????
  45. << Tampa Racing / Driven Concepts / Ellis Autoworkz Present TRack Event 16 ! >>
  46. 96-98/99-00 door conversion question.
  47. write up on crx dash in sedan?
  48. Can anyone help here??? Cooling Temperature gauge problem.
  49. No Spark could this be a bad Dizzy??
  50. help
  51. code 16 injectors
  52. can 3qrts of oil stop vtec from low pressure
  53. WTB: VTEC ECU for '95 Lude
  54. GSR pistons
  55. Weight of a B Series Transmission
  56. type-R cams ?
  57. Now doing swaps and welding
  58. Neuspeed rear strut bar install (pics)
  59. wtt my si wheels
  60. H23 Sleeve question
  61. need help
  62. Good price on tie rods.
  63. Over Heating 97 Civic EX
  64. car boggs from 1.5k to 3k when accelerating.
  65. a/c ground
  66. vtec doesnt engage
  67. difference between vtec & i-vtec?
  68. Oxygen sensors, one vs two/law/tuning/ECU
  69. Looking 4 pair of si's
  70. Help I need a stock ECU for my B16B CIVIC TYPE R
