PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328
  1. no power to my starter the small wire
  2. B18A1 bogs at 3k
  3. What are Rare?
  4. 91 accord erratic idle
  5. i need my turbo rebuilt.
  6. crx dumping fuel in cylinder
  7. 2006 Florida CRX/Civic Meet
  8. block code
  9. clutch/tranny f-d up??
  10. CRX + B16 + Which header?
  11. ITR Muffler?
  12. ITR Rod question
  13. ls swap
  14. shifter bushings
  15. quick ?
  16. Help
  17. Need help civic not running right!
  18. about rota slip center caps
  19. Info About Brakes
  20. compatability for rear lower tie bar
  21. a/c help
  22. Trying to locate a problem..
  23. What clutch is better?
  24. 2.3 Liter RDX engine into TSX??
  25. ek sideskirts on a eg coupe?
  26. Integra clutch problem?
  27. 450 cc injector...what does that mean?
  28. Any one know where i can find....
  29. Where can i get these RIMS????
  30. << Tampa Racing / Driven Concepts / Ellis Autoworkz Present TRack Event 16 ! >>
  31. 96-98/99-00 door conversion question.
  32. write up on crx dash in sedan?
  33. Can anyone help here??? Cooling Temperature gauge problem.
  34. No Spark could this be a bad Dizzy??
  35. help
  36. code 16 injectors
  37. can 3qrts of oil stop vtec from low pressure
  38. WTB: VTEC ECU for '95 Lude
  39. GSR pistons
  40. Weight of a B Series Transmission
  41. type-R cams ?
  42. Now doing swaps and welding
  43. Neuspeed rear strut bar install (pics)
  44. wtt my si wheels
  45. H23 Sleeve question
  46. need help
  47. Good price on tie rods.
  48. Over Heating 97 Civic EX
  49. car boggs from 1.5k to 3k when accelerating.
  50. a/c ground
  51. vtec doesnt engage
  52. difference between vtec & i-vtec?
  53. Oxygen sensors, one vs two/law/tuning/ECU
  54. Looking 4 pair of si's
  55. Help I need a stock ECU for my B16B CIVIC TYPE R
  56. B series turbo
  57. Car Problems
  58. Best parts
  59. what type is this tranny
  60. My current build and some questions.
  61. Stock ls internals turbo
  62. Y8 question
  63. ITR rear sway bar
  64. Need NSX help.
  65. tps sensor?
  66. coupe bumper on 93' sedan?
  67. fuel filter
  68. 92 integra wont start
  69. high Compression Questions
  70. CRX electrical/clutch question
