- b16 wiring
- Quick question???
- Anyone have a stock muffler from any car, they can donate?
- DOHC D-Series
- timing belt 96ex?
- vacume diagram
- Brakes!
- opinion on amount of HP this setup will have.
- Harness q.
- did anyone go to 78th street last night?
- need help with adding hp to my car
- civic gauge cluster question
- want to buy a big turbo for cheap
- thermal wrap?
- car wont start
- auto to manual conversion
- Need 88 civic hood..
- boost HP question??!!
- 91 civic lsvtech
- import builders
- 91 crx cluster wiring
- A/C question. Please help. It's hot here
- WTB 94 wing.
- InsaneCivicSedan
- Dyno'd DIY LS
- b20 swap
- Second gen RX7 injectors into a Honda
- *URGENT* removing stock muffler hangers off...
- Front axel nuts
- obd1 or obd2?
- machine shop needed
- E Brake Cables?
- CRX hung up
- I Funkin Hate My Crx!!!
- Nopi Race Information @ Bradenton
- Another idle/ignition help thread.
- how much?
- 91 cluster in 88 crx
- ATTS Problem
- hubs .. .
- injector ?'s
- wiring ..
- Help!!!!!!!!
- Help Me Please
- Stupid D series quesiton
- 89 LS Teg vs 90 DOHC DSM?
- another weird problem
- Where can I get an H22 running 9psi tuned?
- Little bit of help on Fans not coming on
- Stupid Fuel Gauge!
- A few little problems.. **EVERYONE LOOK PLEASE**
- obd1 or obd2 sensor
- this thing good quality?
- engine rebuild-need hp
- intake mani issues
- ls rebuild. .
- Next H/A Meet - Need your opinions...
- fuel injectors
- Injector question
- trailing arm bushings???
- Fog Lights
- Main relay?
- Carbon fiber hood?
- Engine Check During Accel
- f22 with h23 head
- tokico or koni
- 97 lude SH - Sticky throws
- What kind of dizzy do i have
- gauge?
- May 22 CRX Meet Ride Out Info *Sticky*
- VTEC wont engage after warming up this morning...........
- CRX 5-spd./auto....
- wet nitrous installation?
- $4000 All motor or Boost?
- Mini me swap problem
- throwing codes 4 no reason?
- hasport hydro mtr mounts. . .
- mix/match brakes for my crx:
- thanks dyingfetus!!!
- Whats a safe amount to spray on a stock 97 jdm itr motor
- seats
- bolt on's for 91 teg ls
- energy suspension inserts help please
- motor wont rev past 6k
- Swap
- b16 swap
- h/a meet?
- k20 rex
- problem wit axle
- just curious on a swap.. .
- Pics from H/A Meet
- Car stuttering after 4500 rpm
- h22a swap in 90 accord ex..
- what struts?
- How Much Horsepower Does A D15b Have?
- HOW MUCH HORSEPOWER DOES A D16Y6 motor have?
- oil pumps bseries question anyone please
- ?pistons?
- B18c5 vs B16B
- Greddy SP 2 exhaust for RSX
- brake swap help gsr/eg
- What should i expect from my car?
- 89 crx that needs more kick
- Exhaust Leak---> Power Loss??
- Tranny Problem HELP!!
- What is the best strut tower braces?
- radiator
- tires??help??
- fuel rail tap
- 99 front end on eg hatch
- I need help wiring
- how important is air intake temp. sensor???
- Spark plugs are dry but are BLACK and smell of gas??
- nitrous bottle + ambient heat = boom?
- weird problems
- H22a Turbo
- strut bars
- Supercharger or Turbocharger?
- painting
- Got some goodies in the mail... :D
- hondata?
- Opinions wanted.
- Will a 96 ls motor fit in a 94 ls??
- Too much for a subject
- does anyone have dropzone coilovers and struts on their car?
- Headlight Conversion
- Brembo Cross Drilleds Directions....
- RS*R ExMag Cat-Back
- compressor?
- Starter Relay?
- installation prices
- Whp Guestimation?
- i need advise plz..
- what is this PLEASE HELP me
- Machine shops?
- thowing o2 code with a chiped p28?
- h23 ecu...
- fuel pressure on a b18a1 ??
- 97 dx civic coupe
- help..really quick..where's the evaporator?!?!
- nitrous jet size charts??? anyone know
- New Clutch?
- oil pan question
- d16y7
- estimate?
- when to tune?
- pressure reg
- speedm limiter
- ground wires on plug wires?
- for tranny sadomasochists ONLY
- Helms Service Manuals.. online!
- help on my ls vtec
- D2 vs tein ss Help meeeee
- I broke this....
- Ls running rich..?
- Where to get my ecu chipped???
- What is the most reliable engine swap?
- Need your opinion
- minime swap?
- Turbo teg 00
- Valve Adjustments
- anyone have a UBERDATA turbo B16 base map???
- Idles fine but stalls when coming to a stop, Having to pop start all the time
- engine codes....
- worst luck in the world.. i swear
- how fast can you wrench
- can i use.........(PLEASE HELP)
- whuts the difference..........
- Coilovers or Lowering Springs????????
- A-pillar with gauges for sale cheap!
- what computer do i USE???? please HELP
- N/A or turbo?
- Japanese ITR front end conversion
- Any wiring shops around?
- 2000 Accord mods suggestions
- Crankshaft pulley / Harmonic balancer holder
- Temp gauge.. not working. . fan also .
- EBAY CRX **must read**
- I hate my car. (Fuel Injectors)
- I Need A Personal Mechanic
- Y do my rpms jump around?
- F@#$ing Pi$$@# off
- Will ITR pistons fit in a b20
- Paint Job
- ...question bout transmission for prelude...
- hey is a zc swap faster than a b16
- question about 5th gen auto tranny prelude
- What Oil Weight to use??
- Pics from my nearly completed ZEX setup
- Turbo ignition
- p72 ecu question
- fuel pump r2
- which ngk's?
- witch motor
- wtf grinding?
- skunk2 manifold reworked
- h22
- JDM CIVIC EF8 Gauge Cluster EF9
- Curious, how many members have an H22 under the hood?
- Y80 transmission
- One step closer to being a gear head
- metal shards in oil
- where is the ignition switch connecter at the fuse box?
- ls/vtech
- Paint Codes
- Case of the shakes......
- Pill size?
- mugen chip
- Got datalogging working :)
- h22 hatch or h22 prelude?
- installing coilovers
- i need a lot help with my CRX
- JRSCed Ls Teg. problems...AGAIN!!! Heh
- Strut Bolt
- Nice rex...
- sohc vtec question
- Hooking up the juice soon
- looking for 94-97 headlights and cornors
- Does anyone do body work
- turbo automatic??hmm
- JR supercharged prelude??
- transmission problem..
- Honda/Acura meets?
- something for yall
- Finally a problem I can't solve...
- Removing Intake Manifold Butterflys
- Engine/Tranny ?'s 92-95 EG 4drlx
- header
- TB and Starter question
- still haven't fixed brake problem.
- Iacv?
- problems
- distributor questions
- ls/vtec crx
- wheel hp?
- turn signals
- clutch and intake problems
- Parking lights?
- Why?
- dyno results from my ITR
- 92-95 civic corner lights
- ls with b16 tranny
- pleeeeese help!!!!!!!!!!!
- f22b1 swap?
- Hondata All-motor?
- integra body kit question??
- Motor What ECU
- Leaking Coolant!
- Mugen head gasket..............
- where to get head flange for b-series?
