- 2 questions
- rear main seal accord ex
- quick stupid question
- automatic integra won't turn over(not starter)
- Engine info an head swap info
- help:
- JDM Front finally done!
- CRX Knock sensor question
- eg/ gsr questions
- should i do a motor swap
- running rough
- del sol swap
- Dyno Day Numbers
- 03 Accord bumper removal
- Who Is Cronhack?
- motor problem
- help with honda
- help with honda/acura
- I have my first troll. :) Im so excited.
- lsvtech
- help!!!
- Good website for turbo research?
- looking for some custom work
- no spark in my crx si
- is there a non ricy exhaust
- Online Honda Manuals PDF's
- Need to find SPEED signal wire on ECU on RSX !!! help!
- ITR throttle bracket and cable
- has anyone ever tried this set up b4?
- raceing crx and cvic right now any minute
- Slipping out of 5th
- F*&#ing window
- Is this worthy buying??
- EF DX to Si conversion Question
- should I Blow it
- home made turbo
- need ecu reprgrammed
- OBD2-OBD1 Wiring Harness Diagram
- known problems with 4th genereation hatchbacks
- Difference between b18a1 and b18b1 heads??
- high idle
- Overheating issues.. GRRRR!!!!
- Integra Clutch
- Steering wheel shaking..
- i need a powerful exhaust
- I need engine help
- Replacing fender liner...
- Neptune Ecu
- My Lude will not fire HELP!!!
- camber kit?
- Header Question
- integra exhaust on a civic?
- h22 into an ek?
- why you should use ARP wheels studs!!!
- injector ?
- E Brake Problem
- cant start my civic
- Wow, Honda's/Acura's Are Fun
- Fan wont turn on
- whats a good price for this?
- thought on my other civic
- Can you drive without the heatshield?
- dying starter
- b16 tranny
- b16 head
- engine sleeves and bottom end
- Apexi Exhaust
- If you are able to Customize a Fuel Rail Click Here!!!!! custom work
- I need Help 93 sohc Prelude
- Time for a new starter?!?
- Cluch Installation Help
- cable obd 0 tranny to a obd 1 car
- hids light which color
- a little clicking
- Need a good swap tech!
- Car Tune
- VSS question from cable to hydro..
- Bad O2 Sensor?
- Looking for civic/crx crew
- AEM wideband o2 sensor wiring help
- bearings color codes, ,
- another dumb question.......
- electronic vss
- need help finding parts
- Found out what broke at track day.
- Del Sol Interior
- 92-95 engine swap
- Projection headlight question
- What are you using instead of a 7th Gen Civic Fuel Rail?
- need motor info..
- Bad o2 Sensor?
- uberdata
- Chipping
- Engine Break In
- So.......I'm pissed!!! Going through CV Shafts Like mad!!
- check engine light
- hey...which is faster to autocross? 2001 S2000 or 2004 S2000?
- just installed city lights....
- Vtec wiring
- Zc?
- Need a fender painted body shop rec...
- motor mount ?
- boost dependent e-cutout...yah or blah?
- Jan 22 meet!
- Got some new Lights!!
- b16 hydro lock
- DX SI injector Question
- Wideband Sensors and Units
- 93 civic motor
- arp main studs.. .
- Any Help on MSD install 94 Prelude
- Sideskirts
- E manage
- Dizzy
- Ignitor
- Head Gasket Question
- need to know
- how much boost for a sohc
- running lean and mean
- Phantom Grip.... yay or nay???
- raceing
- how can i remove black paint on my fat five
- Balancing . .
- Important tranny quetion??
- Gsr tranny question. . snap ring ..
- Engine Crane's and Engine stands ...
- new guy needin some help
- high ass idle
- need help
- VIN Question
- is 200 degree coolant too hot?(turbo guys)
- Cam power theory...
- DYNO DAY! Jan 23rd
- linkage pin
- 94-00 integra fuel rail on 90-90 intergra?
- 91 hatch: brake upgrade ?
- teg seats
- Spoon Sports Exhaust
- superchager questions.
- head ????
- minature intake filters
- I need a Clutch alignment tool for 96 civic. Anyone?
- f22 header
- rich as hell
- fuel pump not working
- Where in Orlando can I get a B Series Mount?
- me and my turbo teg are legal!
- LS GSR SI TYPE R Tranny Question
- zex question
- best ecu setup
- What Can be wrong
- Need Help Please!!!!!!!
- motor swap questions
- where is the best place to take a motor
- conversions?????
- any one want to make some $?
- Need daily driver, how much does it cost to go 13's?
- Integra rear motor mount
- ITR Girdle on lsvtec..
- h22 alternator relocation?
- widen oem wheels
- Track Day Recap - Honda/Acura
- auto - 5 speed conversion
- who all went to 1320?
- jdm front end conversion
- engine whining noise???
- Best 2k4 Civic Site?
- Any 04 Civics on this Board?
- Tuners
- laf sensor code 48
- 91 crx
- Spark Plugs
- I Need Help!!!headers&springs Swap!!!
- DC2 cluster in EG... can you do this?
- Anyone every used BFG G-Force Tires?
- trackday callouts
- ECU ??? what kind ???
- does anyone know how to read ECU serial numbers?
- b20 vtec question
- can i put my b16a2 into a crx
- 93 civic ex: starting hard when cold
- partial throttle gheyness
- CRX Interior Conversions
- Tial wastegate sizes...what's the difference?
- ek climate control
- Help with Problem-LQQK inside(READ)
- where can i get ????????
- cheaper honda bearings? were to go?
- 98 and up taillights
- Better Radial?
- hermonic balancer question
- itb's on a honda
- high idle
- Wastegate adapter flange 35mm-44 vband.
- Stripped plastic screw
- My freinds new setup......
- Seafoamed...now Car Won't Start
- Ever put a Y8 manifold on a Z6 head?
- Idle Problem
- vtec wiring question
- Anyone else have a B18 AC bracket?
- rod bearings
- Dyno numbers from my ITR
- f*** up turbo
- D15 swap doesnt start?
- mpfi swap runs!!!!!!
- Axle swap?
- Clutch Troubles
- need help with fuel problem on 92 integra
- A little troubleshooting help..
- i need alot of turbo info please cronic maybe?
- Ebay Pimp Find Of The Day
- Maint Reqd
- Who wants to help
- vtec??
- new toys
- changing bushings help me
- Well The Ls Is Back!
- Squeaky susp. ?
- weight reduction question???????
- computor problem in my crx
- B-20 swap
- price
- Crower 412's ..
- Crx Seat Swap!!!
- Electric hacksaw or blowtorch needed!
- 94-up GSR brakes on a CRX
- Anyone have a distributer i can use?
- ecu/injector ??????
- Bearings ..
- Just cause its there...
- NEED A BIG FAVOR - Poor guy needs a car checked out on carfax
- GSR Engine Problem
- Antenna ?
- Just went and checked my codes, and they are as followed:
- My Dad's 91 CRX Si (56k be careful)
- How Much would these be worth?
- Does anyone know who the owner of this car is?
- help!!
- 96 EK hatch mounts...
- A small sneak peak!!
- help
- I am UPSET!!!
- Lost Motions???
- 91 Accord Problems
