- Toda spec B's - OBD-0 Ls/Vtec
- Need 94 accord ex stock rims bolt covers.
- accord motor swap
- need parts for 1987 Civic 1.5L Carb Sedan 4 door D15A2
- Evaporator on 93 civic went bad need help how to install!!!
- doing brake swap have proportioning valve question??
- i need a mechanic to come to me and adjust my timing!
- What Kind Of ECU is this Auto or Manuel
- Muffler exhaust question!!!
- Presission injector
- needs help!
- How much does a automatic to 5 speed swap cost?
- Crx f/s
- 1998 civic ex wont start after rebuild. Also where is the ecu fuse located?
- ECU Advice GSR
- need help..
- Cast Manifold Vs. Equal length turbo manifold
- Moon Roof glass install..
- Motor on last leg !?!?!?
- ecu fuse keeps blowing in my acura what could it be car wont start now
- recomend shop to change single cam head
- Y8 Wiring Harness In 91 EF?
- D16y7 swap complete???
- Car wont sit right???
- Any info about boost that most people dont mention?
- 01 Accord F23a vtec stumbles on idle and throwing code HELP
- my 2000 front end conversion for my civic wont line up space between hood bumper
- Replacing tired y7 bootom end?
- Will hx rims fit the DA teg
- HELP B series question
- D16Z6 mpg problem
- need help lowering a 1st gen integra
- Stolen 95 Acura Integra GSR
- coilover help on my ek hatch (eg coils)
- A/C overcharged? But How? Need advice
- How low is too low?
- 90 Civic Dx Crank Pulley bolt help!!!!
- Code 43 plz go away help me!
- Why wont my damn dash blink my cels????????
- easy question how hard is a 1.8 swap intoa tired ass 1.5 91 civic?i
- Leaking Honda!!
- Need Work Done To Your Honda????
- B16a2 chugging after 5k
- Why the bike racks?
- 90 integra supercharger help
- Trying to convert Integra Ls stock into LSVTEC
- rad fan stays on with key out
- Really need techs input on this one.
- d16z6 swap in dx crx wound rev idles beautiful
- Urgent Help needed
- Question With Cable To Hydro Conversion?
- Need some opinions...
- 90 EF Hatch closing problem, help please!!!
- Big Problems!
- Need HELP! 01 Integra LS overheating....
- has anyone cut a coil off there Lowering springs
- Will 94-97 Civic Shocks fit 00 Si ??
- I need help! K20 a2 civis si 2002
- h23a1 seafoam problem
- TL swap into dc2??
- need help bad!
- Noob question.. Help!!!
- zc dual cam into eg hatch need help
- need help with injectors
- Megasquirt, AEM, others? What's best for my B18A?
- is the half shaft of a b18b1 the same as the half shaft of the b18a1!!!!!!!!!!!!!
- AIR LEAK...!!!!! helpp!!!
- Single cam help !!!
- Best way to correct for a 1.9" drop on prelude
- Integra Not Accelerating...
