PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333
  1. Radiator help
  2. ****itr***question?****
  3. idle problem
  4. P/w and P/L Anyone know how to install them?
  5. over heating?
  6. Are D16Z6 & B16A Drive axles compitable?
  7. Cam Specs. Jdm B16 - B18 Gsr
  8. center cap for rota wheels?
  9. question about turbo and wastegate
  10. i need help i have a ???? please
  11. G35 HID's
  12. My D16a6 Build...
  13. Problem still going on (BIG PROBLEM)
  14. 53000 rpm civic!
  15. B18b1 machining
  16. integra exhaust
  17. turbo question
  18. bov placement
  19. need help with my h22a prelude!!!!!!
  20. Timing for D15B7
  21. difference between cable and hydro trannys
  22. Honda Accord problems.
  23. New eg owner here
  24. head gasket leak
  25. Help ME I AM BOOSTED!!!!
  26. Front Lower H brace strut installed
  27. Need Spring Help
  28. DOHC VTEC flywheel ob ls
  29. Hondata K-Pro
  30. Vcon Buddy Club VTEC controller??? HELP
  31. dizzy need help
  32. my cars still slow!!
  33. Shifter Movement???
  34. A Site For Wirin And All Things
  35. valve train question
  36. H2B conversion kit
  37. A few how to's
  38. Need help
  39. what clutch to buy 4 bseries cable tranny
  40. alarm stopped working
  41. Turbo supply shop (fittings, lines, restrictors, etc)
  42. grinding Q's
  43. Clutch
  44. DIY request: 90 DA cluster in my 89 crx
  45. ne1 have a busted b series vtec head
  46. crank pulley
  47. Help! Identifying body kits
  48. HELP!!! NEED HElp Bad
  49. d16y
  50. cooler fan switch for Teg?
  51. need help with 91 hatch bumper usdm frontend with jbm bumper
  52. the build I did
  53. Good deal????
  54. t3 rebuild kit
  55. better track car
  56. Alternator Question
  57. B18b Bore?
  58. Cheap Engine safety mod.....
  59. idle temp too high for teg?
  60. 91 Accord Wagon
  61. first honda... need some help
  62. this is enough.
  63. machining cost for a Ls crank and rods!
  64. Any good EG websites?
  65. Quick Question...Please Help!
  66. how to check codes on obd1 ecu?
  67. EF bumper compatibility
  68. i would like some input......
  69. Ecu Question
  70. new clutch!!
