PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333
  1. need hellpp im doin a swap but i got a wiring prob
  2. RSX TYPE-S Leathers in my DA Teg???
  3. Another del sol shift linkage question
  4. Ebay Intake?
  5. 0-60 and 1/4 miles times with SAFC2???
  6. Need Hydro Tranny HELP ASAP!!!
  7. Driver Front Tire Scrubbing?
  8. jdm honda/acura meet
  9. Da Integra Jdm Front Bumper?
  10. Passenger Airbag??
  11. HF Tranny on D16Z6???
  12. Fuse Keeps Popping!!!
  13. need head advice???????????????///
  14. clear headlights
  15. k series ?
  16. Si headlights on 97 coupe ex?
  17. LCA's for an 88 crx si
  18. Del sol B16 in my EJ [shift linkage question]
  19. Fastline Performance shifter.
  20. brake lights on and wont shut off??????
  21. help broke ball joint
  22. hx supercharged power question
  23. i have questions about a p30 ecu HELP !!!
  24. NEED cooling fan help....
  25. questions about my motor?
  26. if i have a obd1 computer that was not on a vtech engine can i use for a vtech one
  27. New Car.new Problems.help!!!!!!!
  28. !!!Anyone has a site for wire tuckin?
  29. power issue?
  30. Acura Integra GSR
  31. Need opinions on a 2000 SI with 144K miles
  32. Please Help!
  33. I need help!!
  34. deal or no deal?
  35. Integra Problem!!!!HELP FAST!!!!
  36. fuel line from rail to filter
  37. CLutch question?
  38. How much money ls vtec
  39. no blinkers or gauges wtf???
  40. greddy oil catch can
  41. 1998 Civic Hatch questions
  42. Fuel gauge problems???????
  43. TRack Day pics?
  44. Custom Headlights??`
  45. (0)(0) Is it bad to rev the engine high if it's not completely warmed up? (0)(0)
  46. sohc?
  47. jdmdreams.net/squadron one meet info 22nd july
  48. waterpump help...
  49. d16z6 ecu ?
  50. Delsol Si Swap-- B16 also cable Trans???
  51. need help with del sol motor swap
  52. where can I get a clutch fork?
  53. 5 lug itr susp on eg 4 door?
  54. Arp headstuds
  55. map sensor
  56. How many miles have you got from your honda/acura?
  57. b20b/z
  58. 00 civic si clutch and pressure plate question
  59. Need A Clutch Alignment Tool!
  60. del sol with ek front
  61. Omnipower MAP Sensor
  62. What Shim/bearing To Use For A Gsr Tranny
  63. obd0 computer will work with obd1 distributor?
  64. where to get dizzy bolts?
  65. a/c question
  66. spare tire question
  67. 90-91 clutch disk + 89' presure plate flywheel ?
  68. suspension/spring/ help lol....
  69. removing alt from b series crx
  70. water temp guage reading
