- bad ac smell?
- y do engines blow up
- Wheels stolen.
- D-series turbo setup
- need help
- where can I buy turbo piping locally
- need help asap upper ball joint????
- 89-94+ teg front clip conversion
- which alternator belt?
- full coil-over setup
- For those who think a stock SOHC head can't flow....
- My head says pr3-4 what is it??
- useuall install price?
- obd0 hondata stage 3
- p72 vs p28
- ek swap ps pump
- please help
- p28 ecu questions
- 97 civic ex gas milage?
- rsx-s or civic-si tranny with 2.4 accord???
- break pedal goes to floor
- 91 Crx Si grey smoke out exhaust pipe
- header question
- gauge pod wiring
- 99 civic hx questions
- engine swap question (best swap?)
- quick question need help...
- type r pistons question
- my DIY painted wheels
- 300-320 hp with a .48ar housing GSR?
- boost help
- 99-00 front end on 92-95 civic??
- WOW.. thats all I have to say..
- VTEC Problems PLZ HELP
- What would I run?
- VIS Z3 fiberglass fenders?
- Vtec In A 00ex
- ecu help
- 1999 civic with b18c1 1/4 mile times, help?
- Cant find raditor motor connector on harness.
- anybody wanna make some cash hauling a car
- i need tranny work done.. I have Money
- Bolt pattern
- front end conversion??
- crankshaft sensor on 96 acura integra
- 92 prelude choking
- Help with BOV
- Bouncing, High Idle
- Need obd0 Pr3 Chipped
- da gauge cluster difference?
- Highest compression on pump gas?
- DC teg JDM front owners, chime in!
- Poll for wheels.
- will this fit?
- oldest accord
- Help me out!!
- radiator question
- turbo oiler line for a crx?????
- Question about what kind of transmission this is???
- Does Somebody Know What Might Be The Problem With My Prelude...
- will ek parts fit eg?
- single cam turbo question???
- changing light bulbd in gauge cluster and dashboard
- T-3 turbo rebuild, help.......
- Seats for 92-95 Civic
- 1.6 Dohc Zc
- 2 wire or single wire for an 02 sensor?
- obd0 to obd1
- Anyone know how to stop the door chime ?
- p28 ecu?
- crx hf to y8 help
- speedo off?
- 1999 Civic Si Turbo B16a
- tach with shift light install
- need respray.......any suggestions
- 95 b18 boost project
- water locked itr
- just curious?
- what half shalf for b16 ef hatch?
- ITR Sputtering Problem
- 2nd opinion/horizontal/flat/vertical/oil cooler mounting
- My Civic is leaning to the Left !?!?!?
- custom car door panels
- B16 Block question.
- Glass roof crx??
- Download Helms Manual
- volk rim size
- check engine light??
- auto ecu in 5-spd car
- Car falls on its face
- fit??
- Whatcha'll think of this...
- starting problems
- Shift light Question
- Need Help With Mini-me
- turbo problems!
- Wiring UK/EDM VT CRX Cluster in USDM CRX
- Engine Lab ( CON ARTISTS)
- Code 9 and 20???
- need help trobule shooting b16 in ef
- ecu
- WHERE to bUy LowEriINg sPriNgs in Tampa
- what shold i do?
- B16A2 Vs. B16B
- question about hxs
- Low compression/SPRAY?????
- Rpm hesitation??
- eg with ls lighting issues.
- vibration under power
- anyway to adjust throw out bearing???
- rack and pinion replacement
- ls swap problem in a 92 hatch
- 97 Integra - turn signal lights FTL!!!
- cable to hydro
- prelude overheating problems
- y8 cam in z6?
- y8 question
- lookin for a local place
- Newest motorheads build
- 91 prelude SI
- dumb ?
- WTB: 88-91 hnda crx sunroof
- KMS valves
- 3rd gen prelude seat options?
- 2.2vtec head on a non vtec 2.3
- no spark in the LS?
- seats????????
- good rpm to launch b16a(2) w/ lsd tranny?
- EP3 Type-R Engine... Average Price???
- Will 90-93 Acura front and rear disc fit on 91 ef honda?
- b16 tranny problems?
- hesitaion while in VTEC?
- f22 to h22 flywheel and other ?'s
- For all B-Series Swaps
- ebay chips for ecu any good
- My LS/VTEC power potential
- b-series swap question
- **HELP! 02 accord cranking and not starting wtf
- Is it the starter or the contacts?
- Guage Clusters
- How do 15s on Crx work out?
- CEL Quastion!
- clutch kit and flywheel for gsr
- Fuel pump not priming????
- How hard would it be...
- 450cc dsm injector install civic
- gsr head swap on an ls???
- need honda mechanic
- Whats wrong with my tranny?
- I've decided what build
- Turbo questions!!! 93 Civic EX
- B20b
- Gauge question
- Runday Sunday Saturday Night Showdown Edition
- obd 2 to obd 1?
- h22 jdm specs
- wtf is the problem with my car
- Would you change EP3 motor for japanese type r?
- How to convert to ls vtec??
- over heating problems
- rain water in motor
- Amazing Honda Commercial !
- Turbo Setup On Ls/vtec?
- b18b ls in a del sol si?????
- Can anyone find???
- Will EK Springs work on an EG ?
- i need a mechanic in st pete area
- Question for you Honda Vtack people
- what size...?
- Couple of trq specs for a B18B1
- rEBULDING QUESTION
- Will this work honda gods?`
- Rims For A Integra Ls
- car doesn't stay on
- LS/vtec all mtr vs LS/vtec Turbo
- THis is fucked up right
- Heat works a turbo?
- turboJdmEk/discs vs drums
- how much
- Help Honda
- Is RSX steering wheel a direct replacement for teg?
- question on dpfi to mpfi on a 88 accord dx
- Ls overheating need advice
- Ef Problems!!!!
- question help
- Crx door panels... help!
- CFM Motorsports
- DA wiring HELP!!!
- LS head differences...
- Lookin for Mechanics/Exterior Repair in Tampa!
- LS/Vtec SWAP NEED Help ASAP!!!!!!
- Cold_beer - Jake
- need mechanic work done
- 8000K HID kit for 99 civic si??
- GSR seats in eg hatch
- turbo with a/c
- b18 help
- f22 qeustions
- how do you know if you fried your clutch???
- ls/vtec engagement problem
- Distributor internals . .. Need Help . .
- prelude (gude) or swap?
- What brake rotor/pads do you run?
- Need some info if this is a good trade or not.
- Stock singlecam power output limit?
- fuel pump cut off switch
- b16 hEAD
- B18B or B20B
- Lightened Flywheel For Turbo
- Anybody have any experience with the NRG Engine Damper?
- i NEED the Fuse Diagram for 94 Tegra... Anyone please!
- Thinking of building a Track Car...
- Map Sensor
- question about a dx and power windows
- Easy Wiring Question
- 94 gold civc hatch stolen!!!
- New help with a diagnostic code
- Lightend Flywheel?
- SCHOOLING Need Opinions
- 98 integra hydro lock
- Need pin location
- coupe ex for crx????? what to do?????
- bracket, need modifiied...
- race gas, con & pros
- Odometer help
- Prelude Help
- What axles are you guys running?
- Block Flushing
- Help With My 94 Acura Integra Gsr
- o2 sensor
- CFM Motorsports (out of business?)
- Gauges Electrical Question
- engine destroyed!
- b20 help PCV???
- 93 civic ex Auto to Man. Conversion help!!
- what should a compression check be on a b18c5
- o.k. here are the pics.
- vacuum/coolant hose confusion, need help.
- Replacing tranny gears
- help/mini-me
- new clutch old flywheel question?????
- check out my new pics.
- Looking at clutches...
- My back up engine
- What should I do...
- new Z6 in my 92 Si
- Engine swap
- turbo teg over heating
- Read PLz!!
