PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333
  1. idleing high n i cant figure out why??? hlp plz
  2. **Need Specs for Skunk2 Cam Gears**HELPi
  3. my civic: worth the work or not?
  4. honda tensioner pulley
  5. Crx hatch leak....anyone else?
  6. need help with my h22
  7. motor prob. need help pleez
  8. f22 a1 a4 a6
  9. suspension question.. 92 civic
  10. 1993 honda civic question
  11. Im new to here
  12. Need Help Now!!! FLASHER
  13. 91 civic
  14. EG Civic Question?
  15. A/c Blower And Radiator Fan Stop Working?????
  16. suggestions/whats needed
  17. Got A Question???
  18. PLease look!!!!!!!!! A/C ?????????????????
  19. need help wiring vtec!!!!
  20. GSR Cable Tranny Q's
  21. what is happening to the honda/acura marktet!!!!
  22. integra third brake light HELP PLEASE!
  23. color code ?????????????????
  24. apexi vafc need help
  25. SOHC head on ZC block???
  26. advice needed badly
  27. Got problem wit my hatch. help pls = )
  28. Radar guns
  29. Follow Mfg's Trans Oil Recommendations Vs 90 Wt?
  30. gauge needles
  31. Compression Question ?
  32. how to take out my alternator in my EF
  33. i keep blowing alternators
  34. jdm honda god i need help zc question
  35. 1.6 Single Cam Si Ecu On A Integra?
  36. quick question
  37. engine bay
  38. ???wastegate Question???
  39. my a/c exploded.
  40. Junkyards - where to find
  41. eBay Intercooler Test
  42. k20 in what
  43. crv swap
  44. need oil pan tapped
  45. Maybe this is a dumb question...
  46. D15B7 Compression
  47. Cluster Help
  48. h22 wiring for 94civic vx
  49. crank bolt issue need help
  50. Maint. required light flashing?
  51. RPMs to high/low on my civic!?!!?!?
  52. 91 Civic EF Question (D16Z6 non-vtec)
  53. need help
  54. is it worth it
  55. harness help
  56. 95~98 / 99~00 Wiring Harness ECU Plug?
  57. exhaust
  58. Code 4: Crank angel postion sensor... HELP!
  59. another axle question
  60. problem wit coolant system
  61. need help in ft myers on crx
  62. s2000 soft top removal
  63. Big engine problems
  64. color code
  65. speedometer/as - weird prblem
  66. Problem on my way to work
  67. god damn airbag light
  68. wiring vtec to switch please help
  69. car shuts off
  70. OBD1 to OBD0 engine harness question
