- air conditioning help
- Any of you Honda people want some work swapping out a head gasket on a 93?
- what do you do when... (read)
- New wheels for the Civic, what offset?
- starting problems
- Moroso Oil pan probs
- lsvtec
- speedometer won't work
- S2000 / subframe questions
- valve adjustment for d15b2
- need help with ac swap
- B Series Vtec Swap into 88CRX
- need help asap horn wont work
- what type of teg is this?
- LS vtec conversion?
- need to put in my tranny
- Fish Smell
- intermittent start problem?
- wiring probs
- question about 4door body parts
- can you put a ls vtec head on a dohc zc
- Need help power window not working on driver side
- redoing eg interior
- one more time * motor mounts*
- tranny
- spun rod bearing
- need help... what do i need to make my ls vtec
- charge pipe question...
- Help Me Tr My A/c Comes On And Off.
- supercharged d15b timing question
- b16 sturdering help???
- Will a ITR front lip fit on a Del sol?
- Car will start when it wants to. PLEASE HELP
- **AnyBody neeD soMe MoneY?* INstaLL!
- B-Series Axle Question
- Want to keep A/C in my EK
- question about window regulator
- the monster h22 build
- what axels do i use??
- can a p75 be chip(ls stock ecu)
- need opinion on bottle cap rims on honda
- h22a timing question..? so lost, need help..
- Rev limit issue
- red honda badges, oem from honda. 20 bucks shipped..
- d17 crank in a d16 block???
- "Old skool" Ef/Da BBQ
- need help changing fluids
- What other rims will fit a 2000 Acura TL?
- What Ecu Do I Need
- anybody ever order products from?
- converting an auto to manual on a rsx
- installing rings and pistons. is it hard?
- How to replace a water pipe on H23
- fixing toe! eating my tires ALIVE!
- 2001 civic . a.c. problems. need someone to fix
- skunk2 stage2 cam problems**** NEED HELP!!!!!!!!!!!!!!!!!!!!!!
- the honda scene has changed so much
- Wanting to go from Ls to GSR
- budget build LS
- Valve Tapping or LMA's????!!!!
- First time turbo owner... wat is there to know?
- front and back rsx seats fit in ek?
- apexi vafc1 issue. please help!
- Swapped CRX exhaust question.
- k20 pistons
- how do iknow if my d15b is a jdm one and
- need a little input
- code 6 on a pr4 0bd0
- immobilizer system 01 civic
- Upper heat shield question
