PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329
  1. help d15b
  2. b17 build ...input needed
  3. overheated engine,now running shitty
  4. wanting to do head swap
  5. I failed at searching :( exhaust help.
  6. Shaving side moldings on a DC teg..
  7. yo racing rear window?
  8. Need Some Info
  9. Good Info/Tech/ Just plain good reading
  10. best oil
  11. hot stuff in here - fresh outta the press
  12. STOLEN PARTS!!!!!!! polk county winter haven area
  13. Chargepipes keep blowing off
  14. Raced my car today for the first time, do you think I did any damage?
  15. 10-11psi on stock internals?
  16. Who does chip ecu?
  17. component fuse keeps blowing????
  18. 94 teg,timming belt,how much or how hard is it 2 put on
  19. offset of 0 on a civic?
  20. Key won't come out after loud pop!!!
  21. wiring dx to si 88-91.....HELP
  22. harness help
  23. >>>Need a DIY D15B7 Timing Belt/Water Pump Install guide<<<
  24. Tachometer going haywire
  25. Worth the work?
  26. Stalling.....?????
  27. ? about civic ecm
  28. Need a Little Help!!!
  29. Halo Issue
  30. 07 Si Problems
  31. 92 accord ex 2.2
  32. help h22 spring & retainer question
  33. 2005 SI seats into an EG Hatch
  34. Question about tires for HXs
  35. eg rhd clip in fl?
  36. Apexi n1 vs. Hks Hipower.
  37. DA suspension question
  38. Tuning to pass emissions?
  39. 4 questions about b20vtec
  40. 99 civic seats in a 93 civic??? yes or no
  41. TTOTD: How to determine if you need a camber kit!
  42. engine swap question
  43. Question/Problem! HELP!
  44. Car is having a rattling problem in 1st-3rd???
  45. 94 GSR rear seat into EG Sedan
  46. del sol starting prob
  47. question about hondata s300
  48. 92 integra
  49. door panel rewire...
  50. Need a stock pan filled and retapped.. who does it?
  51. Need A Truck To Use Plz Look
  52. 96' Acura Integra 4Dr Auto MPG?
  53. need help plz.....
  54. bee r rev limiter
  55. apexi vafc manual
  56. obd1 check engine code
  57. little problem
  58. People with guages... need help.
  59. WHO CAN TURN MY FLYWHEEL??.... and how much
  60. ac
  61. vtec help
  62. d16y8 turbo sparkplugs?
  63. 5 speed crx people help me out !!!
  64. My 97 Ls Integra Wont Start !!!!!
  65. CEL: 9 CYP Cylinder Sensor.
  66. Reputable Bartow/Lakeland Machine Shops?
  67. help with vtec
  68. NGK plug#
  69. wats the best
  70. Pm6...?????
