- Factory spoiler measurements.
- gsr tranny 3rd gear is hard to engage
- uncontrolled idle HELP!!
- P73 JDM ECU Q's
- H22 into civic how to keep ac?
- 99 Integra Exhaust
- Ls integra overheating
- 92 Accord ex coupe
- Sunroof scratching toof
- honda crank pulley holding tool
- car wont start....
- someone help! 3rd gen prelude
- TR I NEED YOUR HELP!! intgrea red lines at 6k with a type r ecu why?? PLZ READ!
- Cuting Off D15 Eg Hatch Need Help Asap
- No compression 2 cylinders WHY!!
- Eg door problem
- 95 civic Turbo Timer problem
- 88 ef hatch idle problem
- K20a2 vs K20a3 Injectors. Can you tell?
- Help Pls!!!!!!!
- Civic problem
- So how hard is to put a k into a eg?
- APEXi V-AFC2 VTEC CONTROL AIRFLOW CONVERTER
- ?b16 tranny in a auto teg?
- Help Read Pls !????
- idle problem
- Teal Eg Hatch Wing Oem 3rd Brake Light
- integra fog lights?
- swap info
- help! injectors
- Valve Stem Seals
- (ALPHA) Unforeseen and unfortunate event
- 90 acura integra wont go over 3000 rpm?
- Composite Fuel Rail
- clutch CHATTER
- D16y8
- Will Bad Clutch Effect Engine Starting?
- registering JDM car in FL
- Help! Asap!
- Header Selection
- Swap Problems
- eg with z6
- 1993 civic speedometer problem
- down or straght pipe? what do i need?
- Alluminum Radiator vs Stock
- Turbo question.....
- helppp me pleaseeeeee!!!!! ahh!
- s2000 questions.
- need help
- i have a d15b vtec motor need some info asap
- Got A tranny Question
- Spindle
- Integra has no spark from distributor...need help
- obd0 car with obd1 dizzy
- Spindle
- i need wiring done
- Different Cluster In Del Sol
- intercooler piping
- dizzy/wiring issues, CRX si w/b18b1
- got a couple things flywheel headers
- eg b swapped prblem [HELP]
- Wondering why?
- SOHC Guys need some help out
- mini-me redline?
- are d and b seeries clutch bolts the same
- just some q and a's
- h23 frankenstein ques.
- 3 wire Iacv . help.
- Great--- I swap my tranny, now i have a miss/hiccup... wtf..
- i need help wit the front bumper lights on my dc, will rep....
